Is this oil fill tube factory?
Trying to figure out if this oil fill tube is factory. I've tried to find similar post but no results. This 350 engine came out of a 1970 truck with factory AC and PS. I know its typical to have a factory oil fill tube like this on the 71-72's with same options but this one is made different. The valve cover hole is the screw in cap type and this fill tube is made to do that, not the push in style.
Michael ![]() |
Re: Is this oil fill tube factory?
Just a wild guess,but could be used for a C40-70 application
![]() Join Date: Dec 1999
According to this page 3929746 is for 1968, 1969-70 366 or 427 engine from a medium duty truck:
http://www.gmpartswiki.com/getpage?pageid=63055 |
#4 | |
Michael ![]() |
![]() Join Date: May 2010
Info in this thread indicates the tube my have been a 4X4 thing as well as some 2WDs.
https://67-72chevytrucks.com/vboard/...d.php?t=781386 |
#6 | |
I should also note the differences I see between the 71-72 oil fill tube and the 70 oil fill tube in question pictured above. The 71-72 oil fill tube looks similar except for these noted differences: the 71-72 support brace is welded to tube, not clamped like pictured. the 71-72 tube will push in valve cover, not screw in like pictured. and the 71-72 oil cap will push in, not screw on like pictured. The 71-72 oil fill tube uses the same rubber push in oil cap as used on the 71-72 valve covers.
Michael ![]() Last edited by 72chevynut; 12-22-2019 at 04:28 AM. Reason: additional information added |
Look up the suffix code on www.nastyz28.com and it will tell you what that engine came out of
72chevynut, your research has clarified something for me. My 327 came from an A/C car and has just the driver-side fill cap, but my truck is non-A/C. I wondered why putting oil in was such a pain. Now, I know. I ought to look for one of those fill tubes to make it easier
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
Jason Banks - Using your link and doing a little more searching I found same part number 3929746 listed used on 1970 Ser 10-20 (4/WD), Blazer (4/WD) w/BB (8 cyl.). I'm not sure what the BB stands for here, it shouldn't be big block because the 4WD models didn't come factory with them. My guess is “with brake booster”, would make sense due to the power brakes was a option then and would limit access to oil fill cap.
http://www.gmpartswiki.com/getpage?pageid=220375
Michael ![]() Last edited by 72chevynut; 12-23-2019 at 09:37 PM. Reason: Additional information added |
#10 | |
Michael ![]() |
#11 | |
V = Flint 02 = Feb. 19 = 19th day TAY = 1970 350 engine, 255HP, 4bolt main, K-10 to 2500 truck I didn't see any VIN stamped on the engine pad for vehicle ID it came out of. I added some pics for reference: AC compressor is off due to weight limits on stand. Engine has correct clutch fan on it now. Clutch fan came with engine but the water pump/fan stud bolts had been robbed, Lol. Finally found some in my parts stash.
Michael ![]() |
#12 | ||
"I ain't nobody, dork."
The rod that it is attached to from the intake looks like a repurposed firewall support for the power brake boster. I have one in my 1972 GMC, bolted from the front of the booster to the firewall.
Gary
Yes it’s similar to the brake booster support rod but different in length and attachment ends. This rod shows no signs of modifications. The oil fill tube itself looked modified with the welds located around top and bottom. After finding this oil fill tube part number listed for 1970 K series trucks and blazer I believe it to be factory first style for our trucks.
Michael ![]() |
