06-14-2004, 06:08 PM | #1 |
Help Water Problems
Help I just wrote a forum about how good my truck was running! but I just drove it in the rain and had BIG problems! I need help figuring out what the problem is. I had just washed my truck before it rained and hosed all of the dirt off of the engine, I don't think that I got anything to wet but who knows? and then it rained pretty hard. When I started it it ran pretty rough and the more I went the more it backfired. Well when I got to my destination it just stopped running, about an hour later I went back and poured some in the carb. and it cranked right up and ran GREAT all the way home?? What is up with that? I have upgraded from points to electronic ign. by the flamethrower kit. and have an open element Edelbrock aircleaner with K&N filter
Brad |
06-14-2004, 06:43 PM | #2 |
Fabricate till you "puke"
It sounds like she got wet.....pull the dist cap, & RTV it to the dist,then get out some good hair spray(like the gals used in the 70's)....yes , i remember that! shoot the cap & wires down with the spray, & try that rain trick again Best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-14-2004, 10:05 PM | #3 |
Ttt !! :-)
06-14-2004, 11:23 PM | #4 |
When I first bought my truck I took it to the car wash and washed the engine / compartment. I wrapped a plastic bag around the carb & dizzy and carefully washed away..... after I was done (let it drip dry in the bay, as there was no one behind me waiting) I went to start it and it turned over and over and would not start, I was lucky enough to have a 10 bay GM service shop next to the carwash and talked to my buddy (GM mechanic) and he loaned me his battery terminal cleaning tool so I did both terminals and vroooom, vroooom. The odd thing was when I pulled the battery cables off the terminals to clean them they looked OK. Later Doug
06-14-2004, 11:34 PM | #5 |
Squirt a little wd-40 in the dizzy cap, it displaces the water that is causing a short circuit.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
06-15-2004, 04:08 AM | #6 |
WD-40 in the dizzy and plug wires nomally work in wet weather.
1968 chevy U.S. Navy |
06-15-2004, 04:20 AM | #7 |
WD-40, short for Water Displacement, Formula 40. Originally designed to offset water, for use on the Atlas Missle project.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
