Old 11-25-2019, 03:08 PM   #1
bb400ho
Active Member
rear leaf spring question
hello, i have a 68 gmc shortbed 2 wd with a leaf spring rear. the springs in it have 8 leafs (i think some were added) and they are 2-1/4 wide. i have a newer rear end in it and i had to use 2-1/2 u bolts and saddles. i would like to buy new leaf springs for the rear. my question is would i have to change the mounts on the frame to go with the easily obtainable 2-1/2" wide springs or is there a bushing that could be shortened?
thanks bryan
bb400ho is offline   Reply With Quote
Old 11-25-2019, 03:09 PM   #2
sstock
sstock's Avatar
Re: rear leaf spring question
Odd you say some were added, my 64 GMC has 7 leaves in its leaf pack and one has been removed.
Steve
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange
1964 GMC 1000 series,custom, 305E, sm420
sstock is offline   Reply With Quote
Old 11-25-2019, 04:41 PM   #3
bb400ho
Active Member
Steve
i could be wrong. when i was looking at replacements i thought i saw 5 as the most leafs you could get.
Old 11-25-2019, 09:07 PM   #4
KY_GMC
KY_GMC's Avatar
The truck probably had the G50 Heavy Rear Spring option. Check your SPID.
You can get replacement springs in 2-1/4" width from SDTruckSprings, but they probably won't have the G50 option. It would be a lot easier to buy those than replace the spring hangers.
Why do you need new springs?
There are measurements on the website that you can use to determine if they are out of shape.
1972 GMC 1500 Super Custom, 383 Stoker, TH350
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592157
Engine Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592233
KY_GMC is offline   Reply With Quote
Old 11-26-2019, 09:19 AM   #5
bb400ho
Active Member
the bushings on the springs are shot and they are kinda pitted. im not sure i need the g50 option. my truck has no spid. there is no evidence of it on the glove box door.
Old 11-27-2019, 10:32 AM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Say Bryan, questions; any chance you have a rear sport bumper? Also, is the hole in your frame for a rear bumper like this? Thank you
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-27-2019, 11:09 AM   #7
bb400ho
Active Member
i will measure when i get home. my truck came with no bumper i bought a sport bumper and brackets from gmc pauls. i have not tried to fit it yet. i moved the fuel tank back there and have a few things to work out first. heres a couple of pics of where i am with the build
Old 11-28-2019, 12:21 AM   #8
71CHEVYSHORTBED402
My favorite color on 67-68, looking great.
Tony
Old 12-23-2019, 08:08 AM   #9
bb400ho
Active Member
sorry it took so long to reply, yes it appears that is where the holes are located,
Old 12-23-2019, 11:08 AM   #10
54blackhornet
54blackhornet's Avatar
Contact Detroit Spring they can build you a proper spring and supply everything you need.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 12-23-2019, 11:21 AM   #11
bb400ho
Active Member
i have used them for springs on a couple of gto's . i have the springs out now and am attempting to replace the bushings. the ones i bought had a 1.250 dia but i need a 1.125 dia. i found them and ordered them just a few minutes ago.
