Old 12-23-2019, 01:10 AM   #1
chtr65
66 K-10 back up light switch
Does anyone have a photo of the correct back up light switch for a 66 K-10 4 speed transmission. Is there someone that offers the correct back up switch for the 4 speed transmission. It appears I have everything but the switch. Thanks in advance.
chtr65 is offline   Reply With Quote
Old 12-23-2019, 03:10 AM   #2
Llay R. Rac
Llay R. Rac's Avatar
Re: 66 K-10 back up light switch
here is a pic of backup light stuff, for 4 speed transmission. i dont know if C-10 is different then K-10.
i dont know of anyone who sells the switch, one post i read suggested trying to find a barrel switch with a push button from an electronic supplier.
1965 Suburban, 2 wd.,292, 4-speed.
proudly owned and operated since Valentines day 1969.
Llay R. Rac is offline   Reply With Quote
Old 12-23-2019, 01:42 PM   #3
chtr65
Thanks for the info. Great stuff. Any chance I can bother you for the length of the switch. Like length overall, length of main body, and then the length of the moving up and down part of the switch. This will help me find the correct switch. It appears I have all the other items intact on the transmission. Thanks Again, I hope you and your family have a great holiday.
Old 12-23-2019, 04:28 PM   #4
Llay R. Rac
Name:  bu switch.jpg
hope this helps.
the button doesn't click, its spring loaded and extends when the lever isn't pressing it.
the button will press in as far as the threaded collar.
Old 12-23-2019, 05:04 PM   #5
aerotruk63
aerotruk63's Avatar
Old 12-23-2019, 06:08 PM   #6
sstock
sstock's Avatar
If you can find a top cover from a 1967 sm420 it has a factory built in reverse contact switch. Much better and very much so less problematic. All else being the same.
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange
1964 GMC 1000 series,custom, 305E, sm420
sstock is offline   Reply With Quote
Old 12-23-2019, 08:11 PM   #7
chtr65
Thanks again for responding with great info. This will help in a big way. Happy Holidays to all.
Old 12-23-2019, 09:24 PM   #8
Bushman66
Can you post the part number on that top cover? Can't quite make it out in the pic...
Thanks!
Bushman66 is offline   Reply With Quote
Old 12-23-2019, 10:31 PM   #9
sstock
sstock's Avatar
Thanks!
Sure
Casting Date August 12, 1966
Casting number 3895779
Old 12-24-2019, 12:43 AM   #10
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
There's a thread in these forums where a member found a newer switch that works.
I'll see if I can find it.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-24-2019, 12:48 AM   #11
LostMy65
LostMy65's Avatar
Here's one of the threads;
http://67-72chevytrucks.com/vboard/s...ghlight=Backup
I think there's another thread where it's shown installed.
Old 12-24-2019, 12:51 AM   #12
LostMy65
LostMy65's Avatar
Found it:
http://67-72chevytrucks.com/vboard/s...77#post6039777
Old 12-24-2019, 01:15 AM   #13
chtr65
Thanks Lost my 65. Huge help. I am a little surprised to see they are hard to come by. Happy Holiday's to all. Once again you guys rock. Now all I have to do is find a good used on, or NOS one. The search begins.
Old 12-24-2019, 02:47 AM   #14
Bushman66
Awesome, thank you!
