Old 12-30-2019, 11:45 AM   #1
J Williams
J Williams's Avatar
Need some of your wisdom!
Okay I need some help here. Trying to build a budget truck and I have run into an issue. Here is the link http://67-72chevytrucks.com/vboard/showthread.php?p=8651205#post8651205?
It’s under the 60-66 build and projects thread and the title is Grandpas 63 C10 build. I know someone out there has an answer to this. Thanks in advance
J Williams is offline   Reply With Quote
Old 12-30-2019, 10:12 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Need some of your wisdom!
The link doesn't work for me and I don't mean to sound like a jackass but you would probably get more responses to your question if you simply just asked it here, in your thread. When we have to go looking for it, it makes it a lot easier to just forget about it and move on. Sooo, fire away, what's the question?
AcampoDave is offline   Reply With Quote
Old 12-30-2019, 10:24 PM   #3
Robert Haas
He did a front crossmember swap and is having a tough time getting the same motor mounts to line up.
Our 1965 GMC big block pro mod build http://67-72chevytrucks.com/vboard/s...d.php?t=746098
Robert Haas is offline   Reply With Quote
Old 12-30-2019, 11:18 PM   #4
J Williams
J Williams's Avatar
Sorry the link didn’t work I just have a lot of info on that other page. Here is the question.....
Okay, so I lowered the engine back in and went to bolt it to the new front cross member and my engine mounts don’t line up. Could use some tips here. I replaced the whole front cross member out of a 78’ Chevy gaining the disk brakes. I used the same engine mounts that I had in it prior to pulling the 350... these are actually the same engine mounts that the original l6 292 rested on. They have been moved to the forward location so my new transmission, the NV3500 shifter will be in the same location. I got the left side mount bolt in then moved to the right side and the engine mount sits about 2” too high on the mount. Any ideas what will work?
Old 12-30-2019, 11:31 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Link fixed.
http://67-72chevytrucks.com/vboard/s...05#post8651205
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-31-2019, 09:32 AM   #6
J Williams
J Williams's Avatar
Originally Posted by LostMy65 View Post
Thanks man!
