Flatout C4 IRS Brake line routing
For those with a 55-59 and a Flatout C4 IRS setup, how did yall route the rear brake lines?
Trying to decide where/how to mount the tab to hold the line from the caliper. Thanks!
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
Re: Flatout C4 IRS Brake line routing
Being the impatient person I am when I have a welder handy, I tacked this in a spot that seems viable...somebody tell me why this might be a bad idea, or else I'm burning it in and dealing with upcoming suprises.
![]() Join Date: Mar 2009
I'm putting C4 into mine but not using the Flatout kit.
edit: Actually I just noticed you will be running your hard line under the frame, I think I would run it through with a bulkhead fitting or over the top.
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ |
that seems to be about where i put mine, but mine are straight up and down. don't worry about being under frame as it is well above the scrub line.
#5 | |
Do you think the line would get crimped somehow?
I think that brake lines running under the frame are vulnerable to rocks, jacks, road debris etc. Don’t think I would do it.
Heres mine, i didnt use the Flatout kit i did my own
Okay, I went ahead and made new tabs that were longer so I could change the mounting position and came up with this spot. I can run the line through the dogbone bracket, over it, etc and it should provide a bit more protection.
I didn't take a photo but I notched the tab to accept the factory C4 rear brake lines. You cant just drill a 5/8" hole and be done with it, the line is keyed to only go in a certain way. I filed in the notches where the line sat most comfortably while mounted in this configuration.
