Old 12-31-2019, 11:06 AM   #1
Artie in Miami
Strange looking dash light ?
While removing an old stereo from my 1986 C20 Suburban, I found a strange looking dash light hanging by it's wire...it has a socket similar to the dash cluster lights...as if it would screw into the cluster...but the wire does not appear to be long enough...and the wire connects to the socket in a very strange way. I am attempting to attach a photo...if anyone can tell me where this connects, I will be eternally grateful !Name:  86 suburban.jpg
Artie in Miami is offline   Reply With Quote
Old 12-31-2019, 11:23 AM   #2
Axle
Axle's Avatar
Re: Strange looking dash light ?
That is an instrument cluster bulb, and that black "wire" is a fibre optic that goes to the ashtray to provide illumination to it.
Alex.
Axle is offline   Reply With Quote
Old 12-31-2019, 11:42 AM   #3
SunSoaked
SunSoaked's Avatar
It's a fiber optic cable that clips into the cigarette lighter. It's fed by a dash light.
SunSoaked is offline   Reply With Quote
Old 12-31-2019, 12:28 PM   #4
Artie in Miami
Many thanks guys !! I had a feeling it was something specialized as it did not look like the other cluster bulb sockets. I had removed the dash cluster last year because water leaked into the dash (cancer around windshield) and killed some of the gauges (volts, oil press, temp). I replaced the gauges (ebay) and must have missed that cluster light. Happy New Year !
Old 12-31-2019, 09:41 PM   #5
Prong
If memory serves, it goes in the upper right corner where your fuel or tach gauge is. They're kind of tricky because they have a tendency to pop out of the socket when you're maneuvering the cluster back into place.
Prong is offline   Reply With Quote
Old 01-01-2020, 12:50 AM   #6
wildwilly4x4
I may be wrong, but doesn't that light clip into the HVAC controls?? Or maybe the fiber optic end goes into the HVAC control... Either way, I am pretty sure it is one or the other.
wildwilly4x4 is offline   Reply With Quote
Old 01-01-2020, 09:17 AM   #7
SunSoaked
SunSoaked's Avatar
Ashtray
Old 01-02-2020, 12:21 AM   #8
wildwilly4x4
Originally Posted by SunSoaked View Post
Ashtray
I am talkin about the light bulb end of it. I know it does not go into the ashtray. I am pretty sure it goes into the HVAC control
Old 01-02-2020, 07:18 AM   #9
Wgesnerjr
Wgesnerjr's Avatar
The light bulb end goes into the gauge cluster (where Prong said) as it needs the printed circuit board to give it a power and ground. The HVAC head unit in my truck does not supply power and ground to the light bulb. That socket is wired directly from the power/ground source via wiring harness. The fibre optic side goes in the ashtray bracket, not that it puts out a lot of light.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 01-02-2020, 09:34 AM   #10
SunSoaked
SunSoaked's Avatar
Nope. Ashtray on one end-cluster on the other. HVAC control- no sir.
