Old 01-02-2020, 11:36 AM   #1
prairieschooner
prairieschooner's Avatar
Cruise Control??
I am wanting to install a Cruise Control on my 1975 C10. Not sure which one would be best so I thought to ask for experienced advice.
Thanks in advance!
Steve 1975 Chevy C10 Short Bed Fleetside
prairieschooner is offline   Reply With Quote
Old 01-02-2020, 04:05 PM   #2
SilverMiner
SilverMiner's Avatar
Re: Cruise Control??
Thanks in advance!
I installed a Rostra Cruise system into my 1980 Suburban nearly three years ago and I've been extremely happy with it. Fairly simple to install and no operational issues since.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 01-03-2020, 08:44 AM   #3
prairieschooner
Do you remember which one & curious where you purchased.
Old 01-03-2020, 12:00 PM   #4
hatzie
Moderator
hatzie's Avatar
Get a Rostra kit if you want to have most if not all of the pieces to install cruise control easily. The brackets looked a little ghetto on the units I saw back in the 90's and the pictures on Summit don't look much better. Fabbing your own is part of the adventure. Dakota Digital sells turnsignal stalks with cruise control switches so you may want to look into one of those rather than the cheap aftermarket looking cruise switches that come with the Rostra kits.
You can piece together a setup based on the ElectroMotor cruise boxes that GM used on the T400 & 4th gen F-Bodies that's essentially the same animal as the Rostra units. It's a scavenger hunt but it's mostly GM parts and can come in at a fairly inexpensive price point.
It should look reasonably close to a stock GM installation when you're done... If:
  1. You carefully choose component placement and build decent brackets where needed.
  2. Avoid the ghetto butt splice and bare wire nightmare i see so often.
    [**]Use Crosslink Poly wire (SXL, GXL, TXL) in the proper gauge.
    [**]Insert the wires in split poly or expanding mesh loom and tie them up keeping in mind there should be droops to allow for body to frame and body to engine and engine to frame movement.
    [**]Use grommets to penetrate the firewall.
    [**]Use drip loops at the terminations and firewall penetration to route water away from these locations.
    [**]Use the original Metripak, Packard, and Weatherpak connectors by extracting the original terminals and inserting the new full length wire with a fresh terminal and seal properly crimped on the end of the harness wires.
    [**]Insert the proper empty cavity plugs in the empty connector holes to prevent water and salt from gaining entry and screwing up the module. Clipped off wires will not protect the connection because water will creep in.
You could also install the 1968-1982 transducer setup that GM called CruiseMaster. If you go this route you'll need to install new vacuum lines, a new vacuum throttle dashpot, and likely replace the vacuum valve on the brake pedal.
Dakota Digital sells replacement cruise control turnsignal stalks that look reasonably stock. You may want to look into one of these for whatever cruise setup you install.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-03-2020, 03:35 PM   #5
prairieschooner
Thanks!
Old 01-04-2020, 10:41 PM   #6
SunSoaked
SunSoaked's Avatar
Dakota Digital.
SunSoaked is offline   Reply With Quote
