Old 01-04-2020, 01:08 AM   #1
tj1970cst
1970 blower motor replacement
I got a new blower motor for my pickup.
Looks like the old one might come on out if I take the hood hinge assy off.
What input do you experienced 67-72 fellas have to make go smooth?
tj1970cst is offline   Reply With Quote
Old 01-04-2020, 09:17 AM   #2
71K1500
Re: 1970 blower motor replacement
Generally the inner fender comes off and possibly the hood hinge.
71K1500 is offline   Reply With Quote
Old 01-04-2020, 02:26 PM   #3
tdangle
tdangle's Avatar
Its tight but you can do it by just removing the hood hinge. I have done it twice. 1st blower motor was from a local autoparts and really noisy.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 01-04-2020, 05:49 PM   #4
71 super
71 super's Avatar
You can do it by just removing hinge. Did my 67 last week.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 01-05-2020, 10:45 AM   #5
toolboxchev
I will second the opinion of everyone here. I will say this though, time wise it does not matter. There is one nut or bolt in the very bottom that is very difficult to get too. The inner fender well pretty much blocks access to this point.
I always pull the inner fender. It just makes for a easier time IMHO and you will be able to inspect other areas at that point normally not visible. I like to know about those unseen issues beforehand.
toolboxchev is offline   Reply With Quote
Old 01-05-2020, 11:54 AM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 1970 blower motor replacement
Where did you get the motor from please. I'm going today and order one from Advance Auto. Along with a new squirrel cage as well.
I have swapped them without removing the inner fender but it's a little harder than if you do remove it.
The thread link below has some info you may need to.
http://67-72chevytrucks.com/vboard/s...d.php?t=697298
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-05-2020, 03:44 PM   #7
67/Heaven
67/Heaven's Avatar
As mentioned, Inner Fender and Hood Hinge. I would add to mark your hinge for position prior to removal. You will avoid having to readjust it when going back on.
67/Heaven is offline   Reply With Quote
Old 01-05-2020, 06:16 PM   #8
toolboxchev
Andy,
As of 2 years ago AutoZone was still stocking them as well as wiper motors. Pretty sure the blower motor was $20 bucks. I thought about investing in them!
Old 01-05-2020, 07:27 PM   #9
rsgt
rsgt's Avatar
I have done this several times, its easy. Prop the hood on that side with a broom handle or stick. Take a small piece of a 2x4 and put it between the hinge and inner fender, take out the three hinge to fender bolts and slide the hood and hinge forward and take out the motor.
rsgt is offline   Reply With Quote
Old 01-05-2020, 09:04 PM   #10
Andy4639
Old member
Andy4639's Avatar
Originally Posted by toolboxchev View Post
Andy,
Found the motor but not the cage yet. I hope LMC has them. I'm fixing to check.
Just checked LMC they have the same one listed for both AC and non AC. Cages and motors are the same part numbers.
https://www.lmctruck.com/1967-72-che...r-conditioning
Old 01-06-2020, 02:33 AM   #11
tj1970cst
Rock auto no cage
