Old 01-07-2020, 11:26 AM   #1
379redneck
379redneck's Avatar
Hydraulic clutch swap
I’m working on getting the parts together to swap my 87 from auto to stick. The donor tranny I have is a mechanical 465 and want to switch it to hydraulic for an easier install as my donor linkage is mangled and welded together. I know I need to get pedals and bellhousing. I was thinking of just buying a new master, slave and lines. Is there an aftermarket kit out there for the pedal that works or can I use the mechanical one from my other truck? Also any other tip or advice would she much appreciated
87 GMC Sierra 2500 4x4 350/TH350/NP203 Flow Tech long tube headers, throttle body spacer, Edelbrock Performer cam, true dual Flowmaster 40s, 6 inch Superlift suspension lift
2000 silverado extended cab stepside 5.3l. Stock for now
379redneck is offline   Reply With Quote
Old 01-07-2020, 11:33 AM   #2
DieselSJ
Re: Hydraulic clutch swap
You need the pedal box that matches your brake booster - vacuum or hydroboost. There are usually a few for vacuum brakes on Ebay. Hydroboost pedal boxes are getting rare. I couldn't find a good aftermarket setup when I converted mine. On the 87, there should be dimples on the firewall where the stock hydro clutch master will mount. I bought a master and slave and used the fittings to convert to AN and made my own line.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 01-07-2020, 02:17 PM   #3
WilliamFd55
I did this on an old build "New year, new body". Tried to copy the link below, not sure if it worked? American Powertrain makes a kit (American Powertrain Hydramax Hydraulic Clutch Release Systems HMGM-01101G). Comes with everything you need. Bolts right up to existing pedal.
http://67-72chevytrucks.com/vboard/s...d.php?t=753110
WilliamFd55 is offline   Reply With Quote
Old 01-09-2020, 12:05 PM   #4
v30crewcab
v30crewcab's Avatar
if you use the american powertrain setup, you need to put a brace between the firewall and original pedal assembly. otherwise you'll break out the firewall. happened to a friends truck using the original hydro pedals without the original braces.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 01-12-2020, 08:51 PM   #5
1957 Chief
I went to a hydraulic clutch when I put the TR6060 in the truck (1986). I used a Wilwood master cylinder kit with a 3/4 bore cylinder. As was said previously, you will need to brace the cylinder against the firewall someway. I made two rods and had one end bolted to the master cylinder and one end to the pedal bracket itself.
Bubba
1957 Chief is offline   Reply With Quote
