Old 01-09-2020, 11:14 AM   #1
66_c10_tpi
Pitman arm hitting sway bar
I have finally got around to installing my CPP 1 1/4" sway bar while rebuilding the from suspension. I temporarily assembled the front suspension without the springs so I could check full travel. The truck is equipped with power steering. When the suspension is fully compressed the pitman arm and idler arm hits the sway bar before reaching the stops. Even without the spacer the arm still hits. Moving the bar forward and with a bracket to attach the bar still hits. I don't like how the sway bar end links would mount without any kind of spacers. The only option I see is to find a different bump stop. Any ideas?
66_c10_tpi is offline   Reply With Quote
Old 01-09-2020, 12:01 PM   #2
jayoldschool
Moderator
Re: Pitman arm hitting sway bar
Perhaps the right choice would be the 70s style truck bar that doesn't use the end links like that one.
jayoldschool is offline   Reply With Quote
Old 01-09-2020, 12:33 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Try removing the lower bushing on the end of the sway bar in the second pic.
Old 01-09-2020, 03:14 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I agree. Lower the bar below the pitman arm.
This isn't mine, but it shows the bar most of us use.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-09-2020, 05:21 PM   #5
forestb
forestb's Avatar
can you flip the L bracket over? Or adjust the angle of the steering box?
forestb is offline   Reply With Quote
Old 01-09-2020, 08:32 PM   #6
jayoldschool
Moderator
That was the point of my post. It is a different bar (and mounting system).
Old 01-10-2020, 12:02 AM   #7
66_c10_tpi
I would love to use this type of sway bar. But finding one is going to be hard in my area. I have checked the pull your parts in my area and no one has one. Most of the trucks here are 4 wheel drive. Plus my control arms are off a 64 truck. They were not drilled for the sway bar so installing later would be difficult.
Old 01-10-2020, 12:17 AM   #8
66_c10_tpi
I don't think adjusting the steering box would be a good option plus the idler arm is also hitting. Flipping the L bracket over would put all of the load on the bolts. The way it is placed now the lower edge puts the downward force on the lip of the control arm plus the bolts. But thanks for the ideas.
Old 01-10-2020, 12:20 AM   #9
66_c10_tpi
I will see tomorrow if this will clear the pitman and idler arms.
Old 01-10-2020, 09:15 AM   #10
The Rocknrod
Moderator
What do the brackets look like that are mounted to the frame in front? Are they the tall or short ones?
I can't tell if it's mounted close to the frame or not, may make a difference?
Old 01-10-2020, 09:46 AM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Do you have and pics from the front of the truck?
Some times the center link gets installed backwards.
Keith
Convert to disc brakes.
Old 01-10-2020, 09:58 AM   #12
66_c10_tpi
They are the tall ones.
Old 01-10-2020, 01:34 PM   #13
66_c10_tpi
This what it looks like after removing the lower bushing. It would clear by about a 1/4".
Old 01-10-2020, 02:33 PM   #14
The Rocknrod
Moderator
You know what 1/4" is?
Old 01-10-2020, 02:41 PM   #15
forestb
forestb's Avatar
I do.
You might want to add some of those mettle cups back in so that those bushings don't get torn up. It might add some unwanted width but you will get more clearance once you tighten down the bolts.
Old 01-10-2020, 02:47 PM   #16
The Rocknrod
Moderator
Ya at least on the top one. Looks like your hitting the bump stop and still have 1/4".
Old 01-10-2020, 04:20 PM   #17
66_c10_tpi
I would put one on the top and on the bottom. I knew that one on the top would have no effect on the clearance. My only concern on doing it this way is that through the motion of the control arm up and down. The bushings would have no room to flex.
