02-19-2016, 12:52 PM | #26 |
Re: Heater Blower Squirrel Cage
Looks like autozone has it, but it's not included with the motor itself.
They have three "blower motor wheel" which are not model specific. P/N: 35446 $14.99, 35448 $12.99, 35218 $29.99 prices are for local autozone here in NJ, so prices may vary. Also make sure you get the correct rotation, some are CW and some CCW apparently. not sure if this link will work or not, if not please try searching for the part numbers above http://www.autozone.com/cooling-heat...s-5-7l-4bl-ohv |
02-19-2016, 12:59 PM | #27 | |
01-04-2020, 08:19 PM | #28 |
Old member
I know this is a older thread but.... Well I just tried installing the AC motor with cage in my 68. It's about 2" to thick. It want work.
All the cages shown are for the AC motor.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-04-2020, 10:20 PM | #29 |
Where's my beer?
Can you make spacer to space it out for the extra depth? That's a popular upgrade to C3 Corvettes, to replacd with a c4 blower motor and cage, for much greater airflow. I had to fab a 3/4" spacer on mine to make it work. People have made them from everything from wood to plastic to aluminum.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
01-04-2020, 11:35 PM | #30 |
This vendor is in Canada. I’ve purchased from them and was satisfied.
Russ |
01-05-2020, 12:05 AM | #31 |
Old member
Suppose to go by advance auto tomorrow. They said they can order the motor and the cage. We will see what they have and I'll report back.
01-05-2020, 09:38 AM | #32 |
That squirrel cage is a pretty standard part. Try looking at older chevy car parts to see if they are the same size.
01-05-2020, 11:46 AM | #33 | |
Old member
Knowing what to call it may help find it on other sites. The cage is called the blower motor wheel. On PicClick search it pulls up 100's of them now with the right wording.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 01-05-2020 at 11:53 AM. |
01-05-2020, 09:02 PM | #34 |
Old member
Ok I went to advance this morning and orderd the cage. I hope it fits one of my motors I have.
Here is what I learned today. Stock 92 truck fan motor with cage will not fit a 67/72 truck heater box without doing some mods. The cage I ordered from Advance is suppose to be 1" shorter than mine so it should work. We will see Wednesday when it gets here.
01-05-2020, 09:12 PM | #35 |
Old member
Just checked on the LMC truck site. The cage & motor are the exact same for either one. AC /non AC!
https://www.lmctruck.com/1967-72-che...r-conditioning https://www.lmctruck.com/1967-72-che...r-conditioning
01-06-2020, 01:18 AM | #36 |
The motor is different for an A/C truck because the A/C motor draws more current. The A/C motor is all that is commonly offered now. I believe some vendors used to list the motors separately, but the heater motors are rare. I would recommend using the higher 25 A fuse amperage and using the A/C fan relay for the high switch setting just like is done in an A/C truck if you will be using an A/C motor on a non-A/C truck. That will help prevent it from burning out your fan switch and the wiring to the fan switch. The factory A/C setup had some of the wiring and that relay that was supplementary to and beefier than the regular cab wiring.
Related thread: http://67-72chevytrucks.com/vboard/s...76#post7825476 High speed fan relay: https://gmcpauls.com/heater_&_ac_2.htm Last edited by dmjlambert; 01-06-2020 at 01:20 AM. Reason: clarity |
01-07-2020, 09:41 PM | #37 |
Old member
Well I have like 6 old blower motors on hand and 2 cages. I hope one of the motors will work with this new cage.
I'm going to put a relay in line to help with the amp draw as well.
01-08-2020, 11:04 PM | #38 |
Old member
Ok I got the cage today and it fits either motor, heater /AC doesn't matter except for one thing. The way it's made it doesn't go all the way down on the motor like the original's do. It doesn't have the right depth inside to go over the motor shaft area. So over all it's the same size as the 92 truck AC motor with the bigger cage. It want work.
So I went with a 72 AC motor with the original cage on it and will have to plug the hole for cooling off I guess. I'll take the new cage back tomorrow and get my money back.
01-08-2020, 11:51 PM | #39 |
Andy, You could build a high volume blower wheel using your original base. http://67-72chevytrucks.com/vboard/s...d.php?t=769582
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
01-09-2020, 10:17 AM | #40 | |
Old member
I had forgotten about that thread thanks!
01-10-2020, 10:01 AM | #41 |
Old member
I ordered the blower motor & wheel last night from LMC. I sure hope it fits.
I will look at building another one though for the ramp truck once I get the 68 done.
