Re: "its all about ol' black"
Excellent seat re-do! Looks fresh but right at home in that cab too.
Well my r/s led tail light got moisture in it and was acting up after 1 year so I emailed United Pacific and they instructed me to go through my ebay seller where I bought it from and no surprise they are not on ebay anymore.
So I shelled out another $150 CND for a replacement from somewhere else which wont happen again! So much for so called epoxy sealed.
100:1 low gear! |
Got some H4 headlights from amazon to replace my candles in glass lol. I think it ads a cool look also.
They fit in but the rubber boot around the terminals is too big to fit in the headlight bucket without modifying the bucket so I chose to leave them off, also I cut thick O-rings in half and installed them between the headlight and hold down ring at the three attaching screws because they are a slightly smaller diameter. They are Brighter but I am going to add relays for full improvement soon .
100:1 low gear! |
A couple of updates -
I got a new back window graphic , I think it suits OL' Black well! Some parts from LMc A relay harness and printed circuit . The printed circuit is a good quality and straight forward swap. Also added the 5 backlit LED bulbs to my cluster, Brighter! The relay harness was only long enough to run in the position I installed and the eyelets on the ground wires were too small for the factory ground bolts other than that all plug and play . Now , just to stay up late enough to see how bright my headlights actually are...
100:1 low gear! Last edited by doubleclucker; 06-09-2021 at 07:22 AM. |
A couple more pics...
100:1 low gear! |
UPDATE for 2022-Still going daily driver workhorse ,no issues with the differentials bought some crane kingpin spring bushing replacement to try out will post when installing.
100:1 low gear! Last edited by doubleclucker; 11-13-2022 at 06:56 AM. |
