Old 12-30-2019, 03:38 PM   #1
nsb29
nsb29's Avatar
Alternator Dilemma
I have a 2009 6.0 out of a Pontiac G8 my understanding is it is controlled by the ECM. My 65 C10 has gauges that I would like to continue to use, Has anyone else worked through this? My local shop doesn’t know for sure if it can be done but is willing to take a look, or possibly an earlier alternator that would be interchangeable
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 12-30-2019, 05:40 PM   #2
kipps
Re: Alternator Dilemma
The gen 4 engines use a three wire "battery current sensor". This functions as an ammeter, and is clipped on the negative(sometimes the positive) battery cable. All three wires from this sensor go directly to the BCM. The BCM talks with the ECM through the GMLAN data lines, and tells the ECM how to adjust the alternator output.
You have several options. Listed below from best to worst.
1. Use the gen 4 alternator with the BCM and current sensor.
2. Swap the gen 4 alternator for a gen 3 alternator. This allows it to internally regulate the voltage.
3. Swap the voltage regulator within the alternator for the gen 3 version. This effectively converts your gen 4 alternator to a gen 3 style. However now, you no longer have an off-the-shelf alternator for easy replacement.
4. Use your gen 4 alternator with no BCM or current sensor attached. Leave it wired to the ECM as stock. It will enter a "fail-safe" mode, and will continuously charge at 13.8 volts. Many folks do this out of simplicity. This will theoretically compromise battery life, charging capacity, and fuel economy.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 12-30-2019, 07:22 PM   #3
nsb29
nsb29's Avatar
Sounds like swapping out to a generation three would be the way to go, and it should still fit in the lower position where it’s at now you don’t have a model number by any chance
Old 12-30-2019, 09:41 PM   #4
nsb29
nsb29's Avatar
Never mind I found it thanks for your help
Old 01-06-2020, 03:47 PM   #5
Daaaanz67
I think member Hartrod made this work without a BCM. Check his post.
Daaaanz67 is offline   Reply With Quote
Old 01-07-2020, 01:35 AM   #6
kipps
If you're referring to this thread, Hart_Rod used option #2 listed above.
Old 01-07-2020, 08:35 AM   #7
nsb29
nsb29's Avatar
Thank you for the input I have already gone to option 2 with the help of the forum and my local generator shop, Who I found out is retiring after 40 something years don’t know what will do without him. I also am changing to a voltmeter so I can still have my gauges. I did run into one small problem as the earlier alternator case was slightly larger and head to you grind a little off the bracket to make it work but no big deal. Thanks again
Old 01-10-2020, 01:20 PM   #8
Daaaanz67
Nope there is another one. I’ll try to find it nut don’t know how to link to this thread.
