Old 11-14-2013, 12:25 AM   #1
FreeRangeChicken
FreeRangeChicken's Avatar
'67 C10 accelerator pedal rod firewall support???
Greetings all, I'm a noob here. Recently got my '67 C10 stepside and I'm in love.
It seems like there are a lot of sources to buy ALMOST any reproduction part you need. However, I've been searching high and low for an accelerator pedal rod firewall support (circled in the attached drawing) to no avail.
Could someone kindly point me toward a possible source for these source for these?
I've looked at Ecklers, LMC, Classic Industries, and various other places after some extensive Google searches. Can't figure out if no one is making them, or if I just haven't hit the right search term.
Thanks for your help.
FreeRangeChicken is offline   Reply With Quote
Old 11-14-2013, 08:52 AM   #2
Lattimer
Lattimer's Avatar
Re: '67 C10 accelerator pedal rod firewall support???
I don't think anybody makes them. Best bet is to search the parts board on here and look for somebody parting out a truck.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 11-14-2013, 09:37 AM   #3
bigmac73
bigmac73's Avatar
could you upgrade to a 72 style? i think those are available online
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 11-14-2013, 09:37 AM   #4
quick60
quick60's Avatar
try one of these places.
http://www.stovebolt.com/ubbthreads/...27878&page=all
http://www.americanpickupsalvage.com/about-us/
http://www.oldchevytrucks.com/
quick60 is offline   Reply With Quote
Old 11-14-2013, 09:53 AM   #5
FreeRangeChicken
Thanks for the tips, guys. I'll check out the parts forum and the other links.
BigMac73, I'm not sure about changing over. It's something I've thought about, but I need to research some more. I think on the later version the whole rod is in the cab and the cable (or carb rod) penetrates the firewall, where on the earlier ones the pedal rod penetrates the firewall and is 1/2 in / 1/2 out. Need to look at that some more. Don't think it would be just a bolt-on swap.
Dave L.
1967 Chevy C10 SWB Stepside, L6 250
1967 Chevy C10 Fleetside, LS2 6.0L
1972 Chevy C10 LWB Fleetside, 350
Old 11-14-2013, 11:37 AM   #6
Lattimer
Lattimer's Avatar
The swap doesn't look to bad actually. Someone on here was making a kit to make it really easy. Its expensive, but Lokar has a kit as well. I considered doing that, but my old school setup still works well.
Shawn
Old 11-14-2013, 01:44 PM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
I converted my '68 C/10 Stepside to an aftermarket/'72 GM set-up. It works great, and I'm happy with the result.
My needs were special: I have a 4-barrel [500 CFM ] Edelbrock carb on an Offy intake on a built 292 L6. The stock linkage was scrapped long ago, and the improvised push-pull bellcrank around a 90* angle to the carb's throttle lever had bad tendencies, like jamming, losing cotter pins, freezing up -- always at the worst times. Also I never got WOT out of my old carb. a 390 CFM Holley.
Since I put the cable on I have had no throttle issues. Maybe the only comment is that at the stoplight, I have to take my foot completely off the gas pedal now, as just light foot pressure causes a 100-200 RPM jump over a 700 RPM idle.
Old 11-14-2013, 02:24 PM   #8
bbcmudtruck
I bought a complete 72 pedal assembly off of a board member on here as well as the conversion kit. If you look in the classifieds section, hes still making and selling the kits. They are very nice and easy to do. The only other thing you will need is a throttle cable. Or if you just want to stick with the rod assembly, go through the classifieds on here and there is always someone parting out trucks in there.
bbcmudtruck is offline   Reply With Quote
Old 11-15-2013, 12:08 AM   #9
FreeRangeChicken
Found a couple of candidates over in the parts board. Thanks for the input.
Dave L.
Old 11-15-2013, 12:32 AM   #10
70c10stepside
I had to get one from a local junkyard. No one makes them sadly.
70c10stepside is offline   Reply With Quote
Old 11-15-2013, 01:30 AM   #11
FirstOwner69
FirstOwner69's Avatar
Here are two just posted on the parts board.
http://67-72chevytrucks.com/vboard/s...d.php?t=604362
FirstOwner69 is offline   Reply With Quote
Old 11-15-2013, 10:13 AM   #12
FreeRangeChicken
Got one of these. Thanks for the link.
Dave L.
Old 08-20-2018, 04:30 PM   #13
lolcopter
I know this is an old thread but I am also looking for the same piece. Anyone know of anywhere to get one currently?
lolcopter is offline   Reply With Quote
Old 08-21-2018, 11:23 AM   #14
michael bustamante
michael bustamante's Avatar
on the parts board theres a guy parting a 69, that will have the pedal assy youre looking for
1967custom
michael bustamante is offline   Reply With Quote
Old 08-22-2018, 01:49 AM   #15
'68OrangeSunshine
I made up a hybrid pf '72GM/Lokar. GM parts inside the cab and Lokar in the engine bay,
Old 08-22-2018, 07:13 AM   #16
Check the parts board.
Old 01-10-2020, 08:48 PM   #17
nailer
Hunting accelerator firewall bracket for a 69 c10 any help would be greatly appreciated thanks
nailer is offline   Reply With Quote
Old 01-10-2020, 11:17 PM   #18
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: '67 C10 accelerator pedal rod firewall support???
I just took my 68 pedal assembly out and put my old 71 assembly in it. I used the lower original mounting hole as a good spot and drilled the other two holes. Went to O-Riellys and bought the Mr Gasket generic throttle cable setup. Had to drill a new hole for the cable but so far it seems like it will work just fine.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-10-2020, 11:26 PM   #19
nailer
Thanks I'd like to get original if possible I'm still looking thanks
Old 01-10-2020, 11:31 PM   #20
tj1970cst
Where did you get that pretty brake booster? Most tenants and stuff I see are painted black.
tj1970cst is offline   Reply With Quote
Old 01-11-2020, 02:05 AM   #21
dmjlambert
dmjlambert's Avatar
When I want original parts I post a want-to-buy ad in the parts section of the forum. Usually somebody responds fairly soon, and offers to sell and ship me the part for a reasonable price, and the hunt is over. I also occasionally post for-sale ads for stuff I want to sell. Have you checked the parts section of the forum to see if anybody has one for sale, or if anybody has a truck they are parting out? Members who have a premium subscription can post for-sale or want-to-buy ads. I recommend subscribing and posting your want.
Old 01-11-2020, 08:35 AM   #22
Andy4639
Old member
Andy4639's Avatar
Talking Re: '67 C10 accelerator pedal rod firewall support???
I ordered it and the master from inline tube sorry..
Old 01-11-2020, 11:29 AM   #23
HO455
HO455's Avatar
I believe that the 60-66 pedal is the same as the 67's.
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 01-11-2020, 09:40 PM   #24
tj1970cst
I ordered it and the master from O-Reilly's auto parts.
You figured it out, just realized my phone changed remans to tenants.
Old 01-11-2020, 11:24 PM   #25
'68OrangeSunshine
No clue of prior years, but MY '67-'68 pedals pivot on a pair of stud-ball ends that are screwed into the floor.
