Old 01-11-2020, 12:29 PM   #51
halfstep
Re: Replaced weatherstripping and can barely close the door!
NC John
I'm interested in the Trique/Altman latches for 67-72 trucks but found zero
photos or write-ups. I tried your instagram link but it doesn't seem to work.
Could you post photo/video links here and/or share more detail?
Thanks.
halfstep is offline   Reply With Quote
Old 01-11-2020, 08:27 PM   #52
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Replaced weatherstripping and can barely close the door!
I just did the GMCPaul press on in my 68 and they fit perfectly. No slaming the doors. If you have to slam it it's not the seals fault. Its the door latch and alignment issues. My doors shut nice and easy and I can lock them both with a key with no problems.
I did have trouble at first but after installing the new latches they shut just fine.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
