Old 01-08-2020, 06:12 PM   #1
Rainman68
help with fuel line / carb info
have a 68 C10 with a L6 250 single barrel Rochester carb with the fuel inlet on the front of the carb. The new pre-bent SS fuel lines I purchased have the inlet to the carb on the right side. I don't know if I have the wrong carb or if I purchased the wrong fuel line. Anyone on here have any suggestions?
You might ask why does it matter where the fuel line goes in? Well I have had this truck for 25 years and have only been working on it for about the last year and I want it to be as original as I can keep it but look as good as I can make it. I don't like the look of cut fuel lines with rubber hoses and clamps. Personal preference.
Did the 68 inline6 250 come with more than one carb option?
Rainman68 is offline   Reply With Quote
Old 01-08-2020, 06:19 PM   #2
truckster
truckster's Avatar
Re: help with fuel line / carb info
I'm not sure about the last part of your question. I sold my straight 6 several years ago, but I believe the fuel inlet was on the right side (engine side).
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 01-08-2020, 08:24 PM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
I could be wrong but I think your truck would have had a Rochester model B carb originally and it sounds like you have MV on there now. I don’t have pics but if you search you should find some on this site.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-08-2020, 08:30 PM   #4
firedemon
my 67 came in on the motor side
firedemon is offline   Reply With Quote
Old 01-08-2020, 09:20 PM   #5
BigBird05
The carb on your engine should have a serial # stamped on it. Get that # and look it up. Then you will know what you have.
BigBird05 is offline   Reply With Quote
Old 01-09-2020, 11:12 AM   #6
drewbert41
drewbert41's Avatar
You could bend one yourself. I was able to do it with pre flared line from NAPA and a $10 China Freight tube bender.
drewbert41 is offline   Reply With Quote
Old 01-15-2020, 02:45 PM   #7
Rainman68
The number on the carb is 7040021. I have not been able to find a site online where I can get the info I need to identify what make, model and years the carb was used. It could be that I don't know to search for the info correctly.
Old 01-15-2020, 03:01 PM   #8
Daves70
Daves70's Avatar
I just did a search. Looks like a MV carb off of a 70 chev/ GMC truck. So it's been changed at some time. I just googled that number with rochester and that's what came up.Can't find carb # try hereNumber
Brand: RochesterType: R1-MV
Number: 7040021
CU: 1-194
General Picture of a R1-MV
Actual Picture
Disc: 70 Chevy & GMC TruckNotes: NotesCyl: Rebuild Kit: KT-5170A /
Check here for Muscle car Info
Float: FLT-100-47 /Acc Pump: 185Choke Pulloff Front: 7002 /Acc Pump Cup: Choke Pulloff Rear: /Needle & Seat: 505XChoke Thermostat:9001 /PowerValve: Jets: Jets Mixture Control Solinoid: Mettering Rods: Throttle Position Sensor: Linkage Rods: / Fuel Fitting:
FuelFilter:
Mixture Screw: Air Cleaner Gasket:
Rebuilt Carburetors
Bowl Gasket: /Carbs Unlimited Rebuild:1-194Middle Gasket: /New Carb/Reman:64-7133Base Gasket: 986 /Core: $
Check the Rochester Parts Page for more parts
We have many parts that may not be listed Call 253-833-4106
This carburetor was made by Rochester , The Rochester Products Division of General Motors was located in Rochester New York and built carburetors for GM vehicles since 1949 . It is a R1-MV . This carburetor has a part number of 7040021 and used on 70 Chevy & GMC Truck . Check here for specific Muscle car InfoReferenced by ; Rochester 7040021
This Site Designed By
EagleHosting WebSite Design ©2006 Carbs Unlimited [terms & policys]
Daves70 is offline   Reply With Quote
Old 01-15-2020, 09:10 PM   #9
Jason Banks
Jason Banks's Avatar
I can't believe I didn't see this when you first posted. I ordered every available fuel pump to carb line I could find for my 68 with a 250. Most of them are wrong. I think I got one that was like original, but I couldn't use it because I have upgraded to HEI. It has been a couple years and I don't remember where the 'good' one came from. When I get to work tomorrow I will see what I can find.
Jason Banks is offline   Reply With Quote
Old 01-15-2020, 09:59 PM   #10
Jason Banks
The correct carb number for a 1968 250 is 7028007 for 1969 is 7029007. I have had a saved search set up on ebay to email me anytime a 7028007 is listed and I think only 1 has come up in the past 3 years. I didn't buy it because it was junk.
I actually have these numbers in my saved search - (7028006, 7028007, 7028010, 7028011, 7028012, 7028013, 7029007, 7029011, 7029012) If it begins with 7028 is is 1968 and 7029 is 1969.
If the carb you have runs good I wouldn't replace it. I have some 704 number carb on mine now even though I have bought a few 7029007 from ebay that need rebuilt. I rebuilt one and couldn't get it adjusted to run as good as the one I took off, so I went back.
