Old 01-20-2020, 08:00 PM   #1
twinshadows
Re: 51 Chev on a S10 frame, named Dale
Thank you , Tempest67, for your time, postings, idea's, and great pictures.
I'm looking & learning as you guys build these trucks. Plus, a lot of the same issues , with different ways & fixes . . . . too make things work.
I'm "in & following along" - - - - - jim
twinshadows is offline   Reply With Quote
Old 01-27-2020, 10:52 AM   #2
Tempest67
Tempest67's Avatar
After looking at the motor mounts that are used for a SBC, it bothered me that the engine rested over the unsupported portion of the mount.
So I thought I would make a few brackets and weld them in for support.
I cut some angled metal to fit in the pocket behind the engine cross member, drilled a hole in it, then drilled a slot in the mount (to match the other 3 slots) , welded it, and ground down the weld.
It still needs to be painted, but here is what I did.
Tempest67 is offline   Reply With Quote
Old 01-27-2020, 11:24 AM   #3
8man
Good solution.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 01-27-2020, 05:52 PM   #4
olcarguy
Looks like you know what your doing...will be following along. What part of Ontario are you from? Been snowing here for last 3 days.
olcarguy is offline   Reply With Quote
