Old 01-19-2020, 11:31 AM   #1
bigmoe
bigmoe's Avatar
Tips for coolant fill?
I'm getting closer and closer to start up. Going to install my RND rad today and hook up hoses. I still have to pick up a steam hose. I read on here a long time ago some tips for filling it with coolant and getting trapped air out but I can't find it doing a search. I've heard some guys jack the front end up to help get air out. Any advice?
bigmoe is offline   Reply With Quote
Old 01-19-2020, 12:07 PM   #2
Rickysnickers
Re: Tips for coolant fill?
I have no experience with LS engines, but I can't imagine they are that much different than standard engines. I have always filled my engine with coolant, about 2"-3" from the top of the radiator fill. Run the engine w/o the radiator cap on it and let the engine come up to temp. This "burps" the engine, getting out all the air. After that's done then I just fill the rest of the way up and put the lid on.
Old 01-19-2020, 01:59 PM   #3
mongocanfly
mongocanfly's Avatar
well they are a little different...remove the top rad hose from the radiator ,tie it up and fill the engine thru the hose...itll keeping purging air..keep filling till no more air comes out of the hose..then hook it back up and finish filling radiator..make sure the heater hose can bypass as well...jacking up front end does practically nothing
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-19-2020, 02:02 PM   #4
prodjay10
Fill through top radiator hose. Connect top hose to radiator and continue filling through radiator. Make sure the overflow tank also has coolant.
prodjay10 is offline   Reply With Quote
Old 01-19-2020, 03:36 PM   #5
bigmoe
bigmoe's Avatar
Thanks guys. Through the top hose it is. Just have to get some heavy 1/4" for the steam line. I have a u-shaped hose on the heater hose outlets for now.
Old 01-19-2020, 05:50 PM   #6
MySons68C20
MySons68C20's Avatar
Fill through upper radiator hose as stated but keep the steam line off until it flows from where it connects to the radiator.
I just did this and it works great.
MySons68C20 is offline   Reply With Quote
Old 01-19-2020, 06:41 PM   #7
LS short box
Couple of things I've done with my LS swaps.
1. If your steam coolant line is connected to the radiator fill just below it to watch for flow.
2. I get them up to temp and then loosen the temp sensor on the left head just enough to get some coolant flow. Be careful that coolant will be hot. And don't over torque the sensor it will break. As me how I know.
Also depending on your radiator setup with the cap off when the thermostat is open you should see a strong flow of coolant coming out of the cooling tubes.
Watch your temp gauge and it's a good time to make sure your fan kicks in if you are running a electric fan
Old 01-20-2020, 01:52 AM   #8
First c10
First c10's Avatar
My father-in-law was a heavy equipment mechanic. He told me always drill a 1/8” hole in the thermostat so it will always have a little flow through the motor. And fill as the rest described. Above all work as long as you keep an eye on it.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-20-2020, 10:45 AM   #9
mongocanfly
the thermostat on mine came with the small id hole in it
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-20-2020, 12:18 PM   #10
ls1nova71
ls1nova71's Avatar
I think all thermostats have a small hole in them. The problem is, if you rely on that, you're essentially filling the block through an 1/8" hole, it will eventually fill, but will take a very long time. Filling through the upper hose is the best way to fill a swap that doesnt have a factory surge tank.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-20-2020, 05:00 PM   #11
Rickysnickers
Thank you for sharing that, so now I know as well. I wasn't trying to lead anybody astray.
Old 01-20-2020, 05:08 PM   #12
sweetk30
sweetk30's Avatar
https://www.lislecorp.com/specialty-...ree-funnel-606
any coolant job these days this is the GOLDEN TICKET . had mine so long i had to buy the update parts that now come in the kits .
fill up till no more goes in . keep funnel 1/3 full only as heated coolant will make it fill up on the first big open cycle .
when all done and happy pinch a big hose by hand and hold it . install plug in funnel . let go of hose . remove funnel kit and adapter and install cap for a 99% no spill job .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-20-2020, 05:57 PM   #13
mongocanfly
shucks Ricky...aint nothing but a thang....the LS is bad to trap air for some reason...that's why we fill the engine thru the radiator hose...
and another thing is the loop hose on the heater hose inlet outlet...i was told not to cap off the heater hose fittings..at the minimum use a 180deg loop hose on them if your not running a heater core.. they say if you don't have flow around the thermostat , it wont open ,sometimes..like I said, some people havnt had any issues and some have..there have been a few on here that had overheating issues and its usually air in the block or heater hoses blocked off
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-23-2020, 05:28 PM   #14
skyphix
How about for those of us that DO have the factory (LS. 2006 Yukon) surge tank and radiator setup? I figure still fill through the top hose, then keep topping off the surge tank? The radiator is also bone dry (new radiator.)
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
