Old 01-23-2020, 01:15 PM   #1
cebra
Wilwood Braided Front Brake Lines
Does anyone know if these will work on a stock C10 with disc brakes? Wilwood Brake Flexline Kits 220-7056...I read all 53 reviews and it appears they may only work on Wilwood calipers or need conversion fittings which I do not want to do. Any other braided line direct replacement options? Mine are rubbing due to my drop spindles.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 01-23-2020, 03:00 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: Wilwood Braided Front Brake Lines
I ordered my front braided lines from Inline tube.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-23-2020, 03:24 PM   #3
cebra
$25 each, done thank you. Also, never heard of them but they have all kinds of oddball parts for our trucks.
Old 01-23-2020, 04:18 PM   #4
1971Stepside
Almost Satisfied
I called them and they also seem to know a lot about our trucks. I was surprised at the various parts they have that aren't brake related.
Old 01-23-2020, 07:13 PM   #5
3767
The wilwood lines are 3/8 24 . got my lines from inline tube and they fit with no problem
3767 is offline   Reply With Quote
Old 01-24-2020, 03:15 AM   #6
mcmlxix
Collector of Projects
mcmlxix's Avatar
www.kore3.com
Rich
1972 K5 Blazer CST Click HERE
Old 01-24-2020, 07:41 AM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Wilwood Braided Front Brake Lines
I used Brake Hoses unlimited on my 71 disc brakes back in 2012 and so far no problems. I had them do the outer sleeve in red.
https://www.brakehosesunlimited.biz/
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
