#26 |
Re: Rodstored-72's 1986 DD build
Looks slightly different vs the Crown part I used. And, a small MAP torch was all it took for me to liquify the bonding agent.
#27 |
chevy truck fan
I had a very big weekend a couple of weeks ago, the weather was clear and warm enough to paint and my friend who paints was able to come over and help….. I FINALLY was able to paint the radiator support, inner fenders and the firewall ….yyaaa!!!. I have never used an hvlp gun before so with guidance from the “master” this “grasshopper” gave it a shot!!
#28 |
chevy truck fan
Well the good is that everything that I wanted painted to get the engine install is painted; I will post about the engine install soon. The bad is that in momentary lapse of judgment I did this
![]() After about a half hour of many words that our not fit for publication ![]() ![]() |
#29 | |
chevy truck fan
yea.. I thought it might be the same as previously shown, but as I got into it I could tell it might not be the same part (it is a crown shaft, just bought through summit on sale). I believe this will work, I have mocked it in place, it just took a little more finessing to work. thanks for the reply... ![]() |
#30 |
chevy truck fan
well.. good news and bad news. I have the motor "installed", but for some reason the pass. side header is hitting the frame??
![]() ![]() thanks!!! ![]() |
#31 |
chevy truck fan
Wwhheewww!! It’s been awhile!! Well I have been busy, just too lazy to update until now. I did a little more research & discovered that it is not too uncommon to have to clearance the pass frame rail just a bit for these motor conversions. I took a few measurements & then rechecked them before any cutting. I used a air cut-off wheel & just took my time to follow my linework. After I cut and took a deep sigh of relief I smootghed the edges with a dremel sanding wheel. I then scuffed the area followed by a swipe of wax-grease remover. Once satisfied that it looked good & everything cleared I proceeded to recoat the exposed area with por-15 frame paint to match the previous painted areas. Everything looks good & almost …. ALMOST looks factory… to an old guy with bad eye sight….
![]() in the picture you can also see the last spark plug wire that I shaved to try to clear the header as well.... I decided that I am going to get a couple of boot protectors for this one & one on the other side too. I forgot to mention that the header flange is "deeper" than the lip of the frame flange - the pic does not show the depth difference. Last edited by rodstored-72; 01-20-2020 at 10:07 PM. |
#32 |
chevy truck fan
The next item up for completion was to get the main Vintage Air A.C. unit installed. I previously talked to a rep. for them at Dino’s get down and was able to confirm my idea of being able to skip using the firewall plate and just transfer the hole size & location directly to the firewall. I liked this because it looked great on my ’72 (with a smoothed firewall) and I did not like the test fit of the plate on my ’86. I tediously tested the hole locations & finally verified that I could install the unit & the holes would be correctly located. After some manly persuasion & finessing it was bolted in place & the lines are situated well, although the lower heater hose line is a little short poking thru for the hose clamp. Overall I am happy with the install
![]() I am now in the process of attaching a few hoses to the unit & the vents. This is frustrating because the hose is round, but the vent/unit ends are rectangular/oval…… ![]() ![]() Helpful hints or method would be gladly accepted…. |
#33 |
chevy truck fan
Well this past weekend I decided to do something that I wished I had done on my ’72….. I prepped & painted my brake booster & bracket. It took A LOT of prepping & cleaning
![]() ![]() Last edited by rodstored-72; 01-20-2020 at 10:51 PM. |
#34 |
chevy truck fan
This MLK day holiday was spent installing the replaced brake proportioning valve. I also replaced the power steering lines. The original one had a small hole from rubbing on something so I decided to replace both. A little FYI for you guys evidently there are 2 versions, a first design & a second design. One comes straight out of the box & the other one bends at a 90 degree. I figured out that the first design (with 90d bend) needs to be my version. In case you guys didn’t know the original hoses will fit the 2013 power steering pump
#35 | |
Here's an idea.... How about making the duct port & hose match where they connect? Or, how about making adapters that allow nice, tight, solid connections vs. having to figure it out on your own? If they have the capability to form & mold a case, one would think ducting that's plug-& play shouldn't be too much of a request.
#36 |
chevy truck fan
LOL...agree. i did the same setup on my ‘72 (universal pieces) so I was expecting some modifications. I read a little deeper in the instructions & noticed the hoses are 2 different sizes- this helps a little. I still scratch my head as to why they have you connect round hose to oval openings, my guess is to help with the overall unit size. I still feel they are the better system, but i am a simple guy & sometimes instructions are confusing
#37 |
chevy truck fan
scotti, thanks for the input...
#38 |
No prob. I'm diggin the build & look forward to your progress.
#39 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Looks great so far! Keep at it!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#40 |
chevy truck fan
thanks guys
#41 | |
#42 |
chevy truck fan
Well not too much to report. I have been busy.... just doing boring tidying up of few things here & there
#43 |
Nice truck, that 4.8 is perfect for a turbo
#44 |
chevy truck fan
superdav,
Thanks!! I keep hearing that (turbo), but I am just wanting a good solid motor that I won't have to "mess with" for a long time. The future may hold other ideas though.... ![]() |
#45 |
chevy truck fan
I am finally adding another “bump” to my posts. I have been busy, but with the boring stuff… cleaning up the wiring. I have done a few “bright and shiny” stuff as well. I started the assembly of the radiator support with the radiator & fans. The wiring was a bit of a mess and I was at first a little overwhelmed, but I remembered some things I saw from other builders on here and I just started with doing a little bit here and there. I took my time and eventually I was able to see the daylight. I feel good about the wiring now and like the cleanliness of it. I used a wrap that I found online it is called Alex tech and it is a split loom that is a “fabric” base. The specs indicate that it can easily handle the heat of the engine compartment and it comes in a few different colors… including red! The turn signal light connectors will need to be replaced, I believe I will get a pair from LMC. On with the pictures…..
Thanks |
#46 |
chevy truck fan
The bright and shiny part was starting the assembly of the radiator support with the aluminum radiator and electric fans. This is the radiator setup that I finally settled on.
Link: https://www.summitracing.com/parts/sum-384030-kit1 I hope that this setup should be adequate for the summers here in the desert. I am hoping that I can use the wiring from the factory motor wiring to connect the electric fans. Hhhmmmmm??? Pictures now… Thanks ![]() |
#47 |
Love the clean wires with the fabric look. I might have to copy that idea
![]() I thought about the same kit from summit too.. please update how you like it and so on. I`d like to compare this to a Buddy running a Kit from Champion |
#48 |
chevy truck fan
elreeso,
Thanks!! Yea I like the loom so far! it is pretty budget friendly too. I was looking for something different like what N2TRUX was using, but thought i would give this a try. I will for sure on the performance of the rad. & fans. I was originally thinking that a H.D. BBC rad. would work with fans but I was guided towards a nice alum rad. and fans due to the L.S. cooling needs. thanks!! ![]() |
#49 |
chevy truck fan
well I have been busy just doing the boring stuff of trying to figure out the wiring for the '13 motor. I did get a start on the dual tank setup, I unboxed a new tank & began the task of trying to figure out "how-to" install the AC Delco 381 fuel pump onto the new '87 sender AND how to install that stuff into/onto the tank.... I posted a few questions on another related thread in here (by the way another great thing about this site!). I will post pics (if I remember!) once I have it figured out...
#50 | |
