Old 05-09-2015, 12:32 AM   #1
SierraMtns
SierraMtns's Avatar
Throttle Cable Conversion
I finished my throttle linkage to cable driven gas pedal conversion and wanted to post about it in case there was other guys looking to do the same thing. The truck is a 67 stepside with a sbc 283.
Picked up 71/72 gas pedal and short throttle cable. Motor is in the 6 cyl position so it sits back closer to the firewall. First I pulled the firewall connection from the cable. Sniped the cable end that goes to the pedal so the cable can be pulled out of the sheath. Cut down the sheath to the desired length and then press it back together.
Drilled a 1/2" hole in the firewall and squared it with a hand file. The firewall end of the cable snapped in place.
Pedal bracket fab up. Drilled the 3 holes that hold the pedal to bracket with a #7 drill bit and then tapped it with 1/4" x 20 tap.
Bolts are all 1/4" x 20. Short ones hold the bracket to the firewall and the long ones hold the pedal to bracket.
More to follow.
SierraMtns is offline   Reply With Quote
Old 05-09-2015, 12:41 AM   #2
SierraMtns
SierraMtns's Avatar
Re: Throttle Cable Conversion
Time to work on the cable. Picked up another cable from Pick-n-pull for $11. The newer 80's chevy cables were stronger and more flexible than the older cables. I grabbed a long one from an 86 GMC van.
Pedal arm end finished just like the factory one.
Finished cable.
Cut a slit in the top part of the arm to allow a 73 and up black clip to hold the cable in place on the pedal arm.
Finished. It feels good and has great throttle response.
Old 05-09-2015, 01:09 AM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Throttle Cable Conversion
Good job!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-09-2015, 07:59 AM   #4
Katrina/10
Katrina/10's Avatar
Nice work. I did something similar with a 69 cab, but it did not have threaded holes in the firewall. I mounted a 71 pedal directly over the 69 holes with a nut plate under the hood. This put the pedal a little further towards the right, which felt more comfortable to me.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 08-13-2016, 02:59 PM   #5
72bowtiestepper
I know this is a old thread, but I like the way you did this....may give it a try before ordering a new shorter cable for my 72 C-10. Great pics showing detail..Thanks a Bunch !!
72bowtiestepper is offline   Reply With Quote
Old 01-25-2020, 08:00 PM   #6
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
I hate to be a thread necromancer but I need the pictures that have been corrupted by PhotoChuckIt in this thread. These are too blurry to be of any use. I am mere days away from finally installing my own gas pedal conversion. Does anyone (perhaps the OP) have these pictures in their original condition?
As a post script I will say that I too was a victim of the PhotoChuckIt holocaust.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 01-25-2020, 10:10 PM   #7
Andy4639
Old member
Andy4639's Avatar
I just swapped the 68 over form the old rods to my old 71 gas pedal. I used the Mr gasket throttle kit from O-riellys and it worked great.
I used the old bottom nut of the 68 old pedal braket and then drilled the two upper holes. Installed bolts and nuts. The Mr gasket throttle kit comes complete with everything you need.
https://www.oreillyauto.com/detail/b...ttle+kit&pos=1
Old 01-26-2020, 12:51 PM   #8
7tee
7tee's Avatar
I clicked on each pic and they came up clear...Hope this helps...
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 01-26-2020, 01:18 PM   #9
HIGHWAY BY THE SEA
This is an edit.
On my phone the pictures are crystal clear.
On my computer it is all PhotoChuckIt logo with out-of-focus pictures. I will use the phone pictures as a reference I guess.
Special thanks to Andy for the cable information!
