Old 01-24-2020, 11:44 PM   #226
joedoh
joedoh's Avatar
Re: slammed 57
OOooOoOOooooo pretty
Old 01-25-2020, 12:34 AM   #227
oldman3
oldman3's Avatar
Re: slammed 57
Nice choice...Jim
oldman3 is offline   Reply With Quote
Old 01-25-2020, 03:52 PM   #228
Black_Sheep
Black_Sheep's Avatar
Re: slammed 57
Originally Posted by slammed57 View Post
The wife says” why you keep starting at them, they’re only brakes” big sigh, she’ll never understand. I always wanted a set of these, needless to say I’ll be busy all day tomorrow putting them on
That sounds like something my wife would say, she doesn't get it either...
Black_Sheep is offline   Reply With Quote
Old 01-27-2020, 03:50 PM   #229
slammed57
slammed57's Avatar
Re: slammed 57
Had to pull the rear axles to put the rears on, not a big deal,
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 01-27-2020, 03:59 PM   #230
slammed57
slammed57's Avatar
Re: slammed 57
Still gotta plumb the brake lines now, should be a crime to hide them behind the wheels!
My 57 current build
Old 01-27-2020, 04:00 PM   #231
oldman3
oldman3's Avatar
Re: slammed 57
Looks good...Jim
Old 01-27-2020, 05:03 PM   #232
mongocanfly
mongocanfly's Avatar
Re: slammed 57
That's a interesting wheel....never seen them with the tig weld like that...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-27-2020, 05:13 PM   #233
slammed57
slammed57's Avatar
Re: slammed 57
its not tig welded, just a pattern done by a cnc machine that gives it a tig look. just an option that billet specilties wheels offer.
My 57 current build
Old 01-27-2020, 06:27 PM   #234
mongocanfly
Re: slammed 57
Ahhhh...ok...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-28-2020, 02:01 AM   #235
joedoh
joedoh's Avatar
Re: slammed 57
that rear wheel looks like a dryer tub!
Old 01-28-2020, 11:37 AM   #236
KMC3420
KMC3420's Avatar
Re: slammed 57
Nice selection of parts on the calipers. The build overall is looking great!
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is online now   Reply With Quote
Old 01-31-2020, 12:23 AM   #237
my56chevytruck
my56chevytruck's Avatar
Re: slammed 57
my friend, you do great work. sure is looking good. Can you hear the engine roar yet? soon though soon.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 02-02-2020, 05:34 PM   #238
slammed57
slammed57's Avatar
Re: slammed 57
thank you sir!
My 57 current build
Old 02-02-2020, 05:35 PM   #239
slammed57
slammed57's Avatar
Re: slammed 57
let me know if you need and cloths dried, we'll throw"em in
My 57 current build
Old 02-02-2020, 05:38 PM   #240
slammed57
slammed57's Avatar
Re: slammed 57
Thanks morrie, as for the motor, I havent tried it yet, I decided to go with a different cam and carb, probably do so around june or july I will address it
My 57 current build
Old 02-03-2020, 12:45 AM   #241
my56chevytruck
Re: slammed 57
A new Cam, with a larger lope maybe?? What about the Carb, why did you change that out?? what did you go with??
1940 Ford Dlx Coupe
1969 Mach1
Old 02-03-2020, 09:35 AM   #242
joedoh
joedoh's Avatar
Re: slammed 57
Old 02-03-2020, 02:57 PM   #243
slammed57
slammed57's Avatar
Re: slammed 57
I have a trick flow cam 270/276 lsa 112. I was going to go with a cam from straub 280/288 lsa 109 ( should be more of a radical idle for what Iam looking for) both cams are hydraulic. as for a carb , I have a demon 750 that i had rebuilt a few years back but Iam goin with a 850 carb from the guys over at AED.
current set up
454 .60 over 4.310 bore 2 main block
4.00" eagle crank 4340
egale 4340 rods
trick flow rollers ( but going instead with morel rollers)
280 trickflow aluminum heads oval ports
single plane intake oval (but goin to get a dual plane on it for better street manners)
balancer ( i still need to get but not sure which to get)
probe pistons right around 11:1 compression
My 57 current build
Old 02-13-2020, 10:37 AM   #244
my56chevytruck
Re: slammed 57
current set up
egale 4340 rods
Just a concern, that big of a carb for the compression ratio may run a bit rich.
1940 Ford Dlx Coupe
1969 Mach1
Old 02-15-2020, 09:20 AM   #245
slammed57
slammed57's Avatar
Re: slammed 57
I thought the same, and still kinda thinking the same as you. those guys over at AED carbs said 850 is good, I asked wouldn't the 750 be more responsive, he said yes but I will be leaving some HP on the table if I went with the 750. But as I sit here and type I am thinking I rather have the better throttle response since Its only a street driven truck and will never see the track. It will probably still have plenty of HP for the street with the 750. What you think morrie?
My 57 current build
Old 03-08-2020, 12:15 PM   #246
Black_Sheep
Re: slammed 57
I would sacrifice a little HP at WOT for better mileage and drivability on the street.
Old 03-09-2020, 12:02 AM   #247
Jason 56
Re: slammed 57
For drivability I’d stay with a 112 LSA cam. A 109 will be lopy but will idle poorly n will have low vacuum. 109 is boarder line street/strip. I’d investigate to make sure it’s what you want
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 03-09-2020, 10:31 AM   #248
my56chevytruck
Re: slammed 57
my .02 worth is you won't need the top end HP, only being on the street and throttle response and a better running engine that will run cleaner is a better choice. is that 850 a double pumper?
1940 Ford Dlx Coupe
1969 Mach1
Old 03-09-2020, 01:06 PM   #249
slammed57
slammed57's Avatar
Re: slammed 57
I agree with you mark. thanks bud
My 57 current build
Old 03-09-2020, 01:08 PM   #250
slammed57
slammed57's Avatar
Re: slammed 57
the cam in it now is a 112lsa. Iam still goin with the 109lsa just because I love the way it sounds.... If I get tired of it I can always throw the 112 back in. I do appreciate bud
My 57 current build
