Mixing Antifreeze Concentrate?
Any Preferred Method You Guys Recommend?
Best Mix, How To Mix, Do i Need Distilled Water? Thanks Posted via Mobile Device |
![]() Join Date: Sep 2014
Re: Mixing Antifreeze Concentrate?
50 /50 mix works down to -20 deg F or more and keeps pump seals happy.
I use distilled if I have it it but usually regular water and I've never had corrosion problems. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Same here. I always buy undiluted antifreeze although it's getting harder to find.... why pay nearly as much for something that's half water?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
It's relly handy to have an empty jug to. That way you can just dump half of the consintrate in the the empty then fill them both up.
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
Here in central Missouri, a 50/50 mix is the ticket. I buy the concentrate and pour half in an older empty bottle...add water, mark the bottles with the word "mix'd" and carry on. I use well water that has some hardness, but not much. Some well water would be too hard IMO and store bought filtered or distilled would be much better.
Under an emergency situation where you too lazy to go to the store...an occasional adding of harder well water isn't going to take the truck down, but I would not make a habit of filling a system that has that slow unknown leak regularly with a hard water mix.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
![]() Join Date: Jan 2001
I keep one of my used antifreeze jugs and pour half of the new one in it. Then I add a half gallon of distilled water and I've got two jugs ready to use.
And you really do need to use distilled water.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Here is 50/50 mix and dont use tap water you have no idea what the mineral content is . For 98 cents a gallon buy distilled specially if you have aluminum in any part of the system.
But best cooling as I have been told is 70%water 30%antifreeze
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
![]() Join Date: Jul 2001
My same method and always use distilled water. Haven't had a radiator leak in can't remember when. Mark jugs as "50/50 New"
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
I've never used distilled water. Just get it right out of the out side tap. Never had a problem. The antifreeze has anticarosive inhibitors in it. But I gess if you want to be safe then by all means use distilled.
#12 | |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
For 98 cents use the distilled water. Then you know you are good
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
I never owned one of those anti-freeze measuring gizmos. When I started driving I read the charts for the mix/temp range and figured 50/50 was sufficient for my situation and have mixed it that way ever since. It's not hoarding to keep one empty jug around, it's being smart. The empties are useful for other things as well. I keep an empty oil jug, too, for carrying used oil to disposal site.
I don't need to mark my mixed anti-freeze in concentrate jugs. If the seal is broken it's mixed.
Every region has differing mineral content in it's tap water, where I live it's so hard you can almost drive nails with it .
As mentioned, shopping around will net you $1 or less distilled water and it's foolish not to use it because you discover you should have used it by the scale that builds up in the cooling system out of sight.... I'm in a Desert clime so I use 60/40, the 40 % being coolant .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#15 |
Yep. That's how I do it.
#16 |
I just keep a jug of both distilled water and unmixed handy. If I fill a new application, I put a gallon of both and then go half a gallon (or quart) of each until it's full.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#17 |
Make sure you run the engine to mix it is there's a danger of a freeze soon thereafter. They won't mix naturally sitting in the system, and the water can still freeze.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
#18 |
A zinc anode installed in place of the drain petcock is also a good preventative measure against corrosion. I have an aluminum radiator as a lot of us do and it is cheap insurance.
#19 | |
Distilled water isn't used to prevent corrosion; it's used to prevent deposits.
#20 |
And what's all this talk about concentrate? It's either antifreeze/coolant or it's mix. That concentrated lingo is marketing jargon. It's not a concentrate, it's just straight anti-freeze. Same as ever. It's their way of reversing the mentality to take thoughts away from the fact that it is just 50% antifreeze/coolant you are buying. Next, they'll be telling us the water they use is something better than what we can get.
#21 |
agree.
#22 |
You want exactly 50-50 in your cooling system. 50-50 will get you to -40 degrees.
The proper way to fill a system is as follows: Find your owners manual. It will tell you how much coolant your systems needs. Usually in quarts. Say it says 20 quarts. After you flush or drain or are done with whatever you are doing, put 10 quarts of pure, undiluted anti-freeze in your system. Top off the system with pure water. Start the engine with the radiator cap off. You need to "burp" the system. The level in the radiator will rise as the engine warms up so have a catch pan under your still open fill neck. Once you see a good flow coming out of the fins inside the radiator, pour in what you caught in your catch pan and then fill the radiator to the top with water. Install cap. Done. Unless you are starting with a totally rebuilt system (engine, heater core, hoses, etc.) you're going to have flush water in the system. By putting half of the required anti-freeze side of the 50-50 mix in the system you know all you need is water to make it 50-50. You also need to burp it so you get all the trapped air bubbles out. After this point, if you puke some out in the spring or fix a small leak, top off with 50-50 and you're good even for a Minnesota winter.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
