Old 02-01-2020, 09:07 PM   #2076
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Put in some time today getting the trans in its final resting place. The mount sits about 3.5” higher than before the dropmember, so to keep from stacking up a bunch of spacers, I cut the crossmember tab off and welded a 1.75” spacer to it. I cut holes to recess the mount bolts—one less thing to drag the speedbumps.
Once mounted, the trans ended up coming into the cab more than I wanted, but the driveline angles are good and everything is clearing. Fluid is filled and shifter is in, now I just need to build a driveshaft tunnel, which is wanting to occupy the same space as my bench seat. I think I’ll rename this truck “5-pound sack”.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-02-2020, 07:53 PM   #2077
gringoloco
A guy with a truck
gringoloco's Avatar
The old girl got some sun today:
-Chris
Old 02-02-2020, 07:58 PM   #2078
gringoloco
A guy with a truck
gringoloco's Avatar
-Chris
Old 02-02-2020, 08:06 PM   #2079
gringoloco
A guy with a truck
gringoloco's Avatar
Terrorizing the neighborhood a bit before the game
https://youtu.be/y2vE6yRqlFI
-Chris
Old 02-02-2020, 08:33 PM   #2080
nlped
nlped's Avatar
Sounds bada$$
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 02-02-2020, 09:22 PM   #2081
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by nlped View Post
Sounds bada$$
Thanks man. Magnaflows are hanging off the end of the collectors as a temporary exhaust. Hopefully it will maintain some of that aggressiveness once the pipes are run all the way out the back.
Bedtime for blue...
-Chris
Old 02-02-2020, 09:37 PM   #2082
Inverter
Inverter's Avatar
Slice n dice... So what is your actual ride height at the front cab mount ?
Beautiful stance.
TROY
My work ~ https://www.67-72chevytrucks.com/vbo...d.php?t=799484
Inverter is offline   Reply With Quote
Old 02-02-2020, 10:14 PM   #2083
gringoloco
A guy with a truck
gringoloco's Avatar
Beautiful stance.
Thanks, pretty happy with how she sits. There’s right at 4” under the front, 4.75” under the rear cab mount, since I like a little ‘hotrod rake’.
-Chris
Old 02-02-2020, 10:28 PM   #2084
SCOTI
SCOTI's Avatar
Lookin gooooood!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-03-2020, 11:17 AM   #2085
cornerstone
cornerstone's Avatar
I have to agree with SCOTI, lookin real gooood!
How are you liking the new trans? Any concerns or adjustments needed or is it perfect straight out da crate shiftin like butta?
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 02-03-2020, 08:33 PM   #2086
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by SCOTI View Post
Lookin gooooood!
Thanks Scoti!
Thanks, seems to be good so far. I haven’t had an opportunity to truly test it, but beating on it a little around the neighborhood, I’m very happy with it. Definitely needs a shorter lever, though...
-Chris
Old 02-04-2020, 12:30 PM   #2087
mcm1209
mcm1209's Avatar
Just went through the entire thread! WOW great work. I'm just starting my build. This has given me so many ideas my wallet is gonna hurt! Wife says thanks!! lol
mcm1209 is offline   Reply With Quote
Old 02-04-2020, 08:42 PM   #2088
gringoloco
A guy with a truck
gringoloco's Avatar
Haha, you’re welcome. If not for this forum, my truck would look entirely different than it does now, and not in a good way. Just paying it forward
-Chris
Old 02-04-2020, 10:06 PM   #2089
TA_C10
TA_C10's Avatar
I hear that man... I wouldn't have made it half as far as I am so far and I'm nowhere close to your build. This forum has led me to so many resources I'm so grateful.
Gringo your truck is sounding good, sitting good, and rolling good. Thanks for giving back man.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 02-05-2020, 10:11 AM   #2090
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I'm glad you didn't crush that beer...with the bumper. Truck looks and sounds great.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 02-05-2020, 07:43 PM   #2091
clay68c10
clay68c10's Avatar
Sounds great and looks great!
I can't wait to be shifting thru the gears in mine.
I did a mid-shift conversion on mine, and just by feel (on the bench) the shifter throws are a bit shorter than in the rear position. Maybe so you can have a longer lever and not end up with a huge throw.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-06-2020, 03:05 PM   #2092
gringoloco
A guy with a truck
gringoloco's Avatar
Much appreciated. This is why we’re here. You guys get me, others maybe notsomuch
Thanks for the kind words. No beers were harmed in the making of the photo, afterwards however...
Thanks man. Yours looks like a cool project. That mid-shift kit is definitely taller than the stock shifter, likely due to the short-shift pivot. I think mine will be ok with a different lever, though I may still do a Pro-5.0 shifter if I feel it’s needed.
-Chris
Old 02-06-2020, 11:32 PM   #2093
gringoloco
A guy with a truck
gringoloco's Avatar
New shift lever installed, much better. It’s 6” shorter, bent back toward the seat, and over toward the driver. Throw is waaay better than before and falls right in my hand
-Chris
Old 02-07-2020, 11:06 PM   #2094
TA_C10
TA_C10's Avatar
So all this time has gone by, how do you like your radio? And do you have courtesy lights installed in foot wells? If so whatcha got?
"It's only money".
Old 02-08-2020, 11:10 AM   #2095
gringoloco
A guy with a truck
gringoloco's Avatar
Unknown. It looks nice enough, and installed relatively easily, though I did modify it to suit my personal desire to have the knobs closer to the dash. As far as sound, I don’t think I’ll know for a while, it is very low on the list of priorities, heck, the only wiring in the truck right now is the bare minimum needed to run the engine. Same for footwell lighting, but if I do it will undoubtedly be a factory-type setup.
-Chris
Old 02-15-2020, 08:56 PM   #2096
gringoloco
A guy with a truck
gringoloco's Avatar
Made a change to the engine setup. I found a screaming deal on this FAST 4-bbl throttle body, which uses all GM sensors, making it plug-and-play with the Holley Terminator-X. It did take a little bit of playing with the tune to get the idle to cooperate, but overall I am match happier with this setup versus the 90mm stock-style. Bonus: the throttle cable and air cleaner fit just as they would with a carb, which is to say without (much) modification
The air cleaner needs paint and I think I’ve changed my mind (again) about the oil fill and knock sensor placement. They are an eyesore and must be eliminated...
-Chris
Old 02-17-2020, 11:26 AM   #2097
knomadd
knomadd's Avatar
Looking good Chris! I'm liking the direction you're headed with the new look of the engine! And every time I see your truck, it makes me want to go drive Brutus, and stab a T56 into my GTO!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-06-2020, 03:18 AM   #2098
smbrouss70
smbrouss70's Avatar
Wow, I've missed a lot. For some reason, I'm not getting emails from this forum anymore.
What's the number on the new stick?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 03-06-2020, 01:52 PM   #2099
TA_C10
TA_C10's Avatar
Yeah me too man, then I found out you have to pay money for the email alerts! lol.
"It's only money".
Old 03-06-2020, 09:54 PM   #2100
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks man. You have nice rides for sure
It’s a Hurst 7438, bolt-on 69 Camaro style. Sitting just about perfect. How’s that Core shifter?
Well, dang...
-Chris
