Old 02-03-2020, 11:44 PM   #1
tdangle
tdangle's Avatar
Frame mount hitch
I purchased a Drawtite hitch 41504, a class 3 hitch with max rating of 1000 lb / 10,000 lb gross weight. Bought at Amazon for $120.
Happy to report install was easy and I was able to keep the spare tire.
I bolted the side pieces to the cross piece of the hitch and then raised it into place after dropping the spare tire. I used C clamps to hold in place while I marked the holes. Drilled 6 1/2" holes stepping up from 1/8" to 1/4" then 1/2". (Hint: Use new or sharpened drill bits)
Bolted into place and raised tire into place. I was not able to secure the tire with the cross piece as the bar was hitting the side plate of the hitch on the passenger side. I placed 2 short pieces of 2x6 on top of the tire to take up the gap between the top of the tire and the 2 bars the top of the tire pushes against and was able to secure the tire.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 02-04-2020, 12:43 AM   #2
Redneck Rydes
Redneck Rydes's Avatar
Re: Frame mount hitch
Looks good!
Redneck Rydes is offline   Reply With Quote
Old 02-04-2020, 09:40 AM   #3
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Glad to see that it fits with the step bumper. How far back does the receiver tube stick out, any, a lot?
Too bad it doesn't tuck up closer though. For $120, I could live with it (or modify).
Thank you for the info!
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 02-04-2020, 11:13 AM   #4
tdangle
tdangle's Avatar
It is about 3 inches back under my bumper
Terry
Old 02-04-2020, 03:08 PM   #5
cornerstone
cornerstone's Avatar
Looks great Terry. Would you mind posting a picture from the lower side view so I can see where the end of the hitch resides?
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 02-04-2020, 04:02 PM   #6
tdangle
tdangle's Avatar
Here you go. As you can see from the underside of the bumper, the drop hitch was welded well. It took a cutting torch and bit of work to remove it. I haven't bothered to clean it up. Let me know if this is what you need.
Terry
Old 02-04-2020, 06:19 PM   #7
Astro-Balls
Astro-Balls's Avatar
Nice, Would that work the same for a '68 LB C20?
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 02-04-2020, 08:53 PM   #8
tdangle
tdangle's Avatar
I would think so. Can't image they changed the frame much if at all.
Terry
Old 02-04-2020, 10:01 PM   #9
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Thanks for the info. My "Buddy" was going to charge $300.00 for the same part #. I ordered it through Amazon.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 02-05-2020, 01:00 AM   #10
davischevy
davischevy's Avatar
Good info.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 02-05-2020, 02:57 PM   #11
cornerstone
It's the perfect shot! I appreciate you taking the time to do that for me.
Brian
Brian
Old 02-13-2020, 10:46 AM   #12
Ol Blue K20
I installed mine yesterday. Fairly straight forward installation and fits nice.
Dale
