Old 01-31-2020, 11:45 PM   #1051
tim_mc
tim_mc's Avatar
Re: What did you do to your truck today.The 3rd chapter
I had a leaky stamped steel valve cover, so used it as an opportunity to get some Chevy LT-1 7-rib cast aluminum ones. GM Performance P/Ns 474207 & 474208. Fel-Pro VS 12869 T gaskets. 1-1/2 x 20" stainless bolts cut down to 1-1/4" did the trick. Bolted on this evening. Fancy for a farm truck, but I should pick up a few HP with these valve covers, yes?
That's a Mr. Gasket fuel 1-6 psi regulator on the fuel line (P/N 9710). The Edelbrock 1405 can handle no more than 4-5 psi, otherwise I get a very strong gas smell.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 02-01-2020, 12:01 AM   #1052
nlped
nlped's Avatar
Moved it out of storage and to the lift. Put the new 20” Torque Thrust’s on it and I dig the new ride height.... the rear bumper AAA sticker is RaD too.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 02-01-2020, 12:08 AM   #1053
Steeveedee
Who Changed This?
Steeveedee's Avatar
Drove to the storage yard and took the batteries out of the trailer to take back home to charge them. Some poor sap was backing his trailer into his spot and hit another vehicle...one of those tall Mercedes units. He only scraped the paint, but you know that that is going to cost a mint. He asked me to spot for him, and I did, so we got the trailer back into his parking space without further damaging the adjacent unit...or his.
~Steven
Simi Valley, CA
Old 02-01-2020, 08:42 AM   #1054
SoCoC10
SoCoC10's Avatar
Installed the restored tachometer cluster, tilt steering column and Comfort Grip Steering wheel in the K10 short bed.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 02-01-2020, 10:01 AM   #1055
Knight72
Bought a new cluster, steering column, wiring harness, and radiator. And started tackling the rusted out inner cowl. Spot weld drilling in a bit.
72 C10 lwb fleetside aka Big Rhonda.
Still plugging away.
Build thread:
http://67-72chevytrucks.com/vboard/s...42#post8247142
Knight72 is offline   Reply With Quote
Old 02-01-2020, 04:45 PM   #1056
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Had a local shop build a 4wd power steering hose using the OEM ends.
Old 02-01-2020, 04:49 PM   #1057
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
That looks good.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 02-01-2020, 04:50 PM   #1058
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks I was pleased - I’m going to use it on the k20 this spring when I update the power steering box. Turns out the guy who built it also has a 1972 Blazer he works on.
Old 02-07-2020, 08:10 PM   #1059
countr
countr's Avatar
Installed my NOS steering wheel that I got from atog (thanks Jeff). And the horn cap I sent to Curtb to have restored (thanks Curt).
countr is offline   Reply With Quote
Old 02-07-2020, 08:26 PM   #1060
tdangle
tdangle's Avatar
This
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 02-09-2020, 03:22 PM   #1061
SwitchbladeII
Wired and tested gauge panel
Got it wired and bench tested. I was able to test all but the tach and oil pressure gauge. The oil pressure gauge did what it was supposed to with power on and grounding the sender terminal. I will have to wait for the final verdict when it's connected to the running motor.
SwitchbladeII is offline   Reply With Quote
Old 02-09-2020, 04:40 PM   #1062
Tommyups
Prepping my bed for paint. I’m going to give the art of painting a shot. Just trying to match the front, old paint job look. If it goes well I might paint the whole thing myself in a couple years.
Tommyups is offline   Reply With Quote
Old 02-09-2020, 07:18 PM   #1063
NewBayColony
NewBayColony's Avatar
Yanked the engine for oil leaks, clutch stuff, 3 speed OD tranny, clean and paint.
72 C20 292 3OTT
77 GMC 2500 4x4 Longstepper 350 4sp
50 3100 ex Airforce/Town of Mendon fire truck
72 GMC 1500 2wd short stepside 250 4sp
78 GMC 2500 4x Longstepper 292 4sp
54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman)
NewBayColony is offline   Reply With Quote
Old 02-09-2020, 09:53 PM   #1064
67C10Step
67C10Step's Avatar
Got the back end of mine all done except bump stops and brake lines. Replaced the last frame cross member as mine was bent up pretty bad. Buddy that I bought my truck from has an old 68 frame so I got it from him. Strppied, primer, painted and bolted it in.
Doing some scrubbing on the rust now and will start front end work soon.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 02-10-2020, 11:11 AM   #1065
OregonNed
OregonNed's Avatar
We had a dry day of opportunity, so the bench was removed to repair the beginnings of a small tear.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 02-17-2020, 08:31 PM   #1066
c10Eric
Just waiting for carpet.
Ps. Sorry my dudes... I can’t figure out how to get the pics oriented correctly.
1968 C10
c10Eric is offline   Reply With Quote
Old 02-17-2020, 10:29 PM   #1067
Steeveedee
Who Changed This?
Steeveedee's Avatar
Drove it back from camping this weekend.
~Steven
Simi Valley, CA
Old 02-18-2020, 05:35 PM   #1068
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
I picked up the bed for mine Sunday! 7hr round trip was worth every mile. Thanks to member Flashed on here.
The bed should match up very well with the cab.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-20-2020, 07:40 PM   #1069
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Actually did it night before last but close enough. Received my first bunch of parts for the small block 400 build that will be going in Ole Greenie so went to friends place that is doing the build and unboxed and checked the parts for damage and correctness.. Next up, the heads in month or 2 maybe 3..
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-20-2020, 10:06 PM   #1070
KQQL IT
At the body shop.
KQQL IT's Avatar
New 15 inch steering wheel from Ebay.
And an old lecarra horn button.
Much improved over the 88-94 wheel that was in it.
KQQL IT is online now   Reply With Quote
Old 02-20-2020, 10:09 PM   #1071
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Received my rebuilt power steering pump from Powersteering.com - Marty does good work
Old 02-23-2020, 07:38 PM   #1072
Daron65
With the weather in the 50s today, I decided to take the truck for a quick ride around the neighborhood. It reminded me that I really need to try and correct the wandering steering problem I have.
1971 Chevrolet C20, Blueprint 355. Holly Street Avenger 430HP. Turbo 350
1952 Chevrolet Deluxe. Stock. True survivor with 1 paint job
1953 Buick Special. GM 355. Just a good smooth engine.
Daron65 is offline   Reply With Quote
Old 02-24-2020, 03:50 AM   #1073
OregonNed
OregonNed's Avatar
Wood paneling project completed - need to get some good pics of the accessories mounted...
Old 02-24-2020, 09:07 AM   #1074
67C10Step
67C10Step's Avatar
OregonNed,
Holy smokes, I cannot even say how good that wood looks! Masterpiece.
I've not gotten up the nerve to start pulling the front end from under mine just yet so I scrubbed her down and rubbed on the rust a bit. Had to do some repairs on my trailer so that was about it for the weekend.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 02-24-2020, 11:42 AM   #1075
Andy4639
Old member
Andy4639's Avatar
I got these last week for the Ramp truck. Next day I left for 2 weeks. I hope to get them installed soon. Maybe even some flame throwers installed to!
