Old 06-17-2004, 11:08 AM   #1
Deuce
Deuce's Avatar
Is the Front suspension off a 71 different than the 73-87??
I have a 80 burb parts truck and a 71 GMC frame I am going to shorten. Is it worth changing the complete front suspension from the 71 to the 80?? Cheaper parts,better susp??
Thanks.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 06-17-2004, 11:18 AM   #2
slam33
slam33's Avatar
They went to rubber bushings on the a-arms in 73
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 06-17-2004, 11:47 AM   #3
Deuce
Deuce's Avatar
Sorry for my ignorance,but would the rubber bushings be considered better??
Old 06-17-2004, 04:24 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
No, they MIGHT ride a teeny tiny bit better, but you probably won't even notice. It was GMs way of (a) cutting a little of harshness out of the ride of the truck and (b) making 8 less places to have to grease on the newer trucks.
For my money, I'd continue to use the 71 stuff. It should already have disc brakes, being a 71, so there is nothing really to gain by changing the parts to newer ones.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 06-17-2004, 04:32 PM   #5
Deuce
Deuce's Avatar
It does have disc brakes. I'll just shorten the 71 frame and keep all the 71 suspension then. Thanks!!
Will the 80 spindles fit on the 71??
Old 06-17-2004, 04:56 PM   #6
Tx Firefighter
if you use the 80 model ball joints and tie rod ends.
Old 06-17-2004, 05:03 PM   #7
Deuce
Deuce's Avatar
So 80 model ball joints will fit in the 71 control arms??
Old 06-17-2004, 05:28 PM   #8
Tx Firefighter
yep, they install just like the stockers.
I can't remeber, but it seems like the 71 lower one is the same as the later years used. Seems like the upper one is the one that needs changed. Check a parts book to be sure.
Old 06-17-2004, 05:43 PM   #9
Deuce
Deuce's Avatar
Thanks for your help.
I just ordered 3" drop spindles for the 71 suspension,4" coils for the rear and a set of shocks all the way around.
Old 06-17-2004, 06:50 PM   #10
tom hand
CCRider
tom hand's Avatar
From my experience....the rubber bushings do ride better on trucks that are lowered with cut/shorter springs...not much difference with stock springs
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-18-2004, 11:13 AM   #11
Deuce
Deuce's Avatar
I ordered the Belltech 3" dropped spindle,so I'm still going to be using the stock coil.
