Old 02-04-2020, 09:08 PM   #1
82sdale
Need measurements for rocker replacement
getting ready to replace rockers. read a lot but cant find any solid measurements. looking for a measurement from some reliable fixed point down to where the top of the rocker should be to ensure the door is going to have room for alignment. anything else that would be useful is appreciated
82sdale is offline   Reply With Quote
Old 02-08-2020, 03:55 PM   #2
stangtjk
Re: Need measurements for rocker replacement
http://67-72chevytrucks.com/vboard/s...d.php?t=741445
Check out the 5th post of this thread.
stangtjk is offline   Reply With Quote
Old 02-10-2020, 11:22 AM   #3
raggedjim
raggedjim's Avatar
I didn't measure anything when I did mine. I did take the door and fender off, and then back on, and then off, and then back on, over and over again until I felt sure everything was going to align.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 02-10-2020, 01:22 PM   #4
jaros44sr
jaros44sr's Avatar
x3^^^^
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-11-2020, 10:09 PM   #5
Huskerboy2
Just my $.02, but I wouldn't fit that rocker without having the door and fender on. Like mentioned above, that might mean taking them off and on more than once.
'72 Chevy Blazer
Huskerboy2 is offline   Reply With Quote
Old 02-13-2020, 09:57 AM   #6
hemi43
hemi43's Avatar
Like others have said, a measurement is useless. Use the door as your alignment jig because at the end, it's what matters. Besides, no two trucks are identical. Back in 1970 some of the tolerances were +-1/4".
hemi43 is offline   Reply With Quote
