Old 02-10-2020, 12:25 PM   #1
jayoldschool
Moderator
Need the rear spring install pic from FSM
I'm at work and my FSM is at home. Can't find an image of the rear spring orientation. Looking for the image that shows the orientation of the spring on the lower control arm. The one that shows the end of the pigtail and the notch +-30 degrees (or something like that). Putting new coils on a truck today at school, but had to take off the mounts to do some fab repair.
jayoldschool is offline   Reply With Quote
Old 02-10-2020, 01:22 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Need the rear spring install pic from FSM
Close as I got
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
