Old 02-11-2020, 08:30 AM   #1
chrismoore701
chrismoore701's Avatar
paint stripper
What a joke, unless there is truly something out there. I have an old can of stripper that was cutting through the repaint, but no the original on my 70. Thinking its Lacquer. So I bought some Zip strip. used this on my 79 and it worked great. This new government regulated formula I dont think even stripped the wax. all it did was leave me with a slimy mess that got all over everything when I was forced to use a wire wheel.
Any other options out there besides mechanical? or blasting
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 02-11-2020, 12:32 PM   #2
Dead Parrot
Re: paint stripper
Might read this thread over on the Steel Soldiers site: https://www.steelsoldiers.com/thread...e-carc.184055/
Talks about removing coats of paint laid down over the military CARC paint. One of the suggestions was DOT 3 brake fluid. Be careful with your experimentation. Many of the suggestions involved flameable and/or deadly stuff.
Ran into this a couple years back doing a house remodel when I needed to remove several layers of old paint. The new and improved stripper had all of the mess of the old stuff with little of the paint removal properties. Wound up using a lot of 60 grit sandpaper and dust masks.
Dead Parrot is offline   Reply With Quote
Old 02-11-2020, 12:51 PM   #3
Ziegelsteinfaust
Re: paint stripper
The paint stripper wheels for the angle grinder work great.
Eastwood makes a special grinder for there wheels that is amazing. Pricey but works great.
If you want there is soda blasting, and some guys do it as a side buisness on the weekends. Plus they will come to you. It gets cheaper if you clean the mess up.
Ziegelsteinfaust is offline   Reply With Quote
Old 02-11-2020, 04:54 PM   #4
chrismoore701
Re: paint stripper
I have the Eastwood stripper. The problem is pushing down on the roof. May reinforce it with some wood See what happens. Best luck I have ad is a wire cone on 90 degree grinder
Chris
