Re: Cab Band Rivet/screw location
73-80 & 81-87 two different width and clips for the year break down.
The easy way to do this is get you molding and clips. Use masking tape to show your top of the molding clip, find you top under the window of your molding. Measure space between the clip holes center. measure space on clip top to the bottom including the space edges then make off you cab back with masking tape center them on the hump panel in the space of where your molding will go. Do not forget to set up the sides too test fit. ** you need the clips to for the spacing rivet stud. For the set up for what ever your setting up your cab for Molding 73-80 or 81-87 clips to match molding your using.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
