Old 02-20-2020, 09:43 AM   #7
focusedontheprize
focusedontheprize's Avatar
Re: Rear bumper bracket holes
Originally Posted by SCOTI View Post
I got some pics for you from my dually. I added some text to help w/the numbers. 1, 2, & 3 are the bolts that retain the inner & outer brackets on mine.
#3 is approx. 5" from the edge of the frame rail & only goes through the last hole on the inner/longer bracket.
#2 is approx. 1.5" from the edge of the frame rail.
#1 & #2 go through both inner & outer brackets.
Thank you very much SCOTI! Neither of the set of holes reflect those dimensions, so I am going to plug weld them and probably have to start fresh. I appreciate the information.
focusedontheprize is offline   Reply With Quote
