Old 02-21-2020, 12:26 AM   #1
CJ2A
CJ2A's Avatar
LS1 LQ4 tie in to a 1963 GMC
The stock LS1 wiring harness plugs in easily to the LS1 engine and computer
What I am looking for is the wiring diagram to tie in a 1963 pickup to this LS1 engine and computer. How do I wire in the 1963 GMC ignition switch to the LS1 starter, computer, and alternator ? Anyone have a wiring diagram ? What did you do with the extra original wires going to the original starter ?
Do I worry about the computer knowing the oil pressure ? Or do I tie I the oil pressure into my gauges manually ?
Do I worry about the computer knowing the engine temperature ? Or do I tie the temperature into my gauges manually ?
48 CJ2A
63 1500 GMC (LS1 w/ Muncie 4spd)
68 RS Camaro
71 K20 BBC & granny 4 speed
95 2500 4x4
17 HD2500 4x4
Want => 67 C10 short bed w/ Manual Tranny
CJ2A is offline   Reply With Quote
Old 02-21-2020, 02:48 AM   #2
mongocanfly
mongocanfly's Avatar
Re: LS1 LQ4 tie in to a 1963 GMC
I replied to most in your other post..
to finish up
the ecm doesn't need to see oil pressure...remove the LS sender and youll need a metric to standard bushing..itll screw in the back of the block in about the same spot as a sbc, then use your reg sending unit in it
the ecm does need to see water temps..it uses the front drivers side head location for this...most of us drill and tap the pass side head, at the back, from metric to npt and install the water temp sender for the gauges there...
curious you have LS1 and LQ4 listed together...those are different engines...LS1 is a 5.7..LQ4 is a 6.0
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-21-2020, 10:03 AM   #3
CJ2A
CJ2A's Avatar
What I got from the numbers is an engine out of a 2005 Chevy Pu and I thought it went 6.0 LS1 LQ4
I will look
48 CJ2A
68 RS Camaro
95 2500 4x4
17 HD2500 4x4
Old 02-21-2020, 10:25 AM   #4
Thealien
Thealien's Avatar
I will look
WATCH THIS VIDEO ON LS HISTORY
Starting near the end for me? Just restart it, lots of info.
Last edited by Thealien; 02-21-2020 at 10:27 AM. Reason: Video was starting at the end?
Thealien is online now   Reply With Quote
Old 02-21-2020, 10:54 AM   #5
cj847
cj847's Avatar
This site has everything you need to know to put virtually any FI chevy engine in anything. Great site.
http://www.lt1swap.com/
cj847 is offline   Reply With Quote
Old 02-21-2020, 12:59 PM   #6
CJ2A
CJ2A's Avatar
I thought my engine was out of a 2005 Chevy. Last weekend when I was getting the ECM cleared I took the attached photo. I think I have a 05 Chevy engine and a 04 GMC ECM. I had the attached photo on my phone, I will look into this when I get home from work later tonight
48 CJ2A
68 RS Camaro
95 2500 4x4
17 HD2500 4x4
