Old 02-21-2020, 04:25 PM   #1
Awann99
Brake lines conversion tips
I’m working on a friends 1965 gmc. He still has the single master cylinder but it needs to be replaced along with his brake lines. I told him it would be best to swap to a dual master cylinder, disc brakes and stainless steal lines for safety if he plans to daily drive it. He doesn’t want the disc brake swap at the moment due to money but he does want a dual master cylinder. I checked brothers and inline tube and they do not carry dual master cylinder lines unless you are converting to disc brakes. The engine is in the truck so bending a custom line would be a pain. Would it be better to use 67-70 drum brake lines because the frames are the same? Or use the disc brake conversion lines with drum brake hoses. Thanks.
Awann99 is offline   Reply With Quote
Old 02-21-2020, 04:43 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Brake lines conversion tips
If hes gonna have all drums then you need a master cyl for drum brakes..
If hes gonna do a disc upgrade later, then he will need to swap the master to a disc/drum master cyl..
And the prop valve will need to match whichever setup he uses
You dont have to use stainless lines though..but the lines wont matter which ever setup he choses..they just transfer fluid
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-21-2020, 05:19 PM   #3
Awann99
I agree. But if he swaps to a dual master cylinder he will need two sets of lines. One for the front and one for the back. And then later he can swap the a drum distributor block for a proportioning valve when disc brakes are install. 60-66 lines use only one brake line and Brothers, inline tube etc only carry dual master cylinder lines fit a disc brake swaps. 67-72 frames are the same so could you use 67-70 drum brakes lines on a 63-66 to gain a dual brake lines while staying with drums.
Old 02-21-2020, 05:53 PM   #4
mongocanfly
True he will need 2 separate sets of brake lines...1 for front,,,1 for rear
But what I'm saying is the brake lines dont care what kind of brakes you have..they just move fluid...your either connecting the flex hose to a caliper for disc ,or a wheel cyl for drums...doesn't matter what kind of brakes you have..
The master cyl does matter....if he runs drums he needs a drum/drum master cyl
If he switchs to a disc/drum setup he'll need a disc/drum master cyl...
I gather your looking for brakes lines that "fit" the truck...but parts stores carry premade brake lines that you can bend to fit...if you need them cut to a specific length a brake shop can cut and reflare the line for you if you dont have the tools...I have my own flare tool...I buy the long premade tubing from oreillys and a handful of threaded fittings and build my own....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-21-2020, 10:55 PM   #5
Captainfab
60-66 Nut
I would use a '67-'70 C10 master cylinder as well as the lines. The '67-'70 drum/drum trucks do not have a proportioning valve, just a block with the pressure switch in it.
Old 02-21-2020, 10:57 PM   #6
0ldSoul
0ldSoul's Avatar
If you're looking to help your bud stick with drum/drum but update that master cylinder to dual for safety reasons, check out this thread by ChiefRocka
http://67-72chevytrucks.com/vboard/s...ht=brake+lines
"a NEW drum/drum master I picked up at Kragens for under $30...I asked for a 67-70 IMPALA drum/drum car...non Power Booster....Can't beat the price !!!"
0ldSoul is offline   Reply With Quote
Old 02-21-2020, 11:14 PM   #7
SidsChopShop
On my 1966, I converted to a manual dual port system. I rebuilt the drums and used a new master cylinder for a 1967 truck, no prop valve; and bought a new stainless line kit from Inline Tube (P/N CTB6607) , to my knowledge this is still the only manufacturer of a 64-66 dual line conversion kit.
I have used this current setup as a daily driver and weekend hotrod 9 months out of the year since 2014 and have had no problems. Hope this will help aid your decision, good luck!
SidsChopShop is offline   Reply With Quote
Old 02-23-2020, 01:16 AM   #8
jocko
jocko's Avatar
Here's how I did it - Single to Dual Res Master Cylinder Conversion
Old 02-23-2020, 01:25 PM   #9
jayoldschool
Moderator
Easy: 67 C10 drum/drum non power master. Use the original single line down, split that line to the front brakes (on the FRONT port of the master). Use a one in/two out block here. Run a new line from rear port of master to the original rear line, using the appropriate union. Under 50 bucks, even if you use a pre-flared line.
jayoldschool is offline   Reply With Quote
Old 03-01-2020, 10:02 PM   #10
richards72chevy
richards72chevy's Avatar
Does the front line on the master cylinder go to the front or rear brakes on your set up? I've heard different opinions on here about this.
richards72chevy is offline   Reply With Quote
Old 03-01-2020, 10:11 PM   #11
jayoldschool
Moderator
See my post #9. Front port to front brakes on these.
Old 03-02-2020, 06:24 PM   #12
SidsChopShop
Yes. front port, front brakes
Old 03-02-2020, 08:58 PM   #13
Rac65
I did my 65 just like Jayoldschool said and it works fine. I am sure power disc would be great but at the time money was an issue.
Rac65 is offline   Reply With Quote
Old 03-03-2020, 08:56 PM   #14
richards72chevy
Thank you.
