02-22-2020, 07:17 PM | #1 |
Parking Brake Cable Question
On my K1500 the parking brake cable hook located on the passenger side near the fuel line area is actually touching the metal fuel line. There are no other holes in frame nearby, so I believe I'm using the proper hole. I'm curious what the proper length of this hook should be? I have a hook that is a little shorter(photo attached), but it also touches the fuel line. The parking brake hook is touching the fuel line, not the vent line. The next hook is towards the front of the truck and is a longer hook, this longer hook turns the cable toward the adjusting hardware/bolt and nut. Any info or photos would be appreciated.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
02-22-2020, 09:00 PM | #2 |
Re: Parking Brake Cable Question
I Could be wrong Tim, I think my 72 K5 Blazer had a longer rod, on the passenger side.. about 8"......From Iron Caine...Post 140.... .....http://67-72chevytrucks.com/vboard/s...=786335&page=6
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 Last edited by notsolo; 02-22-2020 at 09:10 PM. |
02-22-2020, 11:12 PM | #3 |
Do you have a photo of the next parking brake hook that is farther down the frame. I have the same length hook as you do in the location shown in your photo. Also, you won't have fuel and vent lines exiting your Blazer like a truck has. Thank you your info and help.
02-23-2020, 04:23 AM | #4 |
This is off a 71 SWB, 2WD. Your first pick looks very familiar less that hook.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
