Old 06-15-2004, 11:29 AM   #1
69sixpackbee
Anybody Running An Edelbrock Carb?
Are these AFB Edelbrocks any good? I remember running one I got used from a buddy and it did'nt run worth a crap. Maybe it was just that carb. I will put it on a stock 402 with a Performer intake?
Pros? Cons?
Thanx!
69sixpackbee is offline   Reply With Quote
Old 06-15-2004, 12:18 PM   #2
busterwivell
I run them on everything I've got. I first got one to replace a Holley that was giving me fits. I've never had a problem with any of the five I've had. A friend just bought one at a swap meet used for 75.00, replaced the Q-junk on his Suburban with it, and it smoothed out the idle issue and runs fine again.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 06-15-2004, 12:19 PM   #3
69sixpackbee
How are they on gas? I am going to use this on my camper truck and I get around 9MPG now with the Q'jet.
Thanx!
Old 06-15-2004, 12:25 PM   #4
busterwivell
Don't know compared to a Q, but it was better than the Holley.
Bill - Tucson, AZ
01 Chevrolet Tahoe
Old 06-15-2004, 12:27 PM   #5
68 Suburban
68 Suburban's Avatar
Thanx!
I am getting 19 mpg on my burb with a 350. You have to tune them correctly, but that is easy. I have never had a problem with my edelbrock. I have been very happy with it.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 06-15-2004, 01:03 PM   #6
DeepPurple
Real Deep...
Carter AFB's are good carbs, don't need much maintenance, and are easy to tune.
Edelbrock even makes a little kit to tune the carb (different needles and such) to your liking.
As far as fuel mileage...
It can be tuned to be aobut the same or a little better on the fumes than a Quadrajet, but more than likely it will be a little worse due to the larger primaries. Additionally if you buy the 750 cfm version I think it's tuned more for performance anyway. (Key note there, I dunno for sure, and once again it can be tuned)
Of course the advantage is that the initial acceleration is so much better than a quadrajet (tuned or not) it's silly. And you don't have any more leaking plugs/float bowls.
$.02
1970 GMC C10 (Deep Purple)
383/700-R4
Mass Modifications
1976 GMC K5 Jimmy (Big Blue)
400/TH350
Coming soon to a drive-in near you...
We have done So Much with So Little for So Long..
We are now qualified to do Anything with Nothing.
DeepPurple is offline   Reply With Quote
Old 06-15-2004, 01:13 PM   #7
COBALT
COBALT's Avatar
I'm pretty happy with mine too. The only thing I would warn you about is getting the right idle mixture, the right needle and seat diameters, and the right fuel pressure from the fuel pump. All of these factors can either leave your engine running rough at idle, and off-idle, or it can run like a top. It's also a good learning experience to buy a "bolt-on" carb like that and then tune it exactly the way you want it.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-15-2004, 01:29 PM   #8
69sixpackbee
The 1411 is the one I was thinking about getting. I will probably invest in the tune kit as well if I decide to go that route. I have the Performer intake in it right now and I made an adapter plate out of ground aluminum plate (K100) so I could put the square bore on the spread bore intake without the vacuum loss issues. When I tried the one I borrowed from my buddy I did remember that the part-throttle was more responsive but it had a cough and stumble that I did'nt like. I did'nt tune it out because the carb was on borrow so I pretty well convinced myself that they suck at that point. I guess I am starting to revisit my previous opinions and try it again. All I know is when I go on vacation back out to Texas in August the last thing I want to have to do is put more gas in it then I want to. At least when I get past Arizona the price of petrol will be considerably less than it is here so that is a big +!
Old 06-15-2004, 01:54 PM   #9
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I have a 1406 and a performer intake on my 350. I can say that it runs great, I have no problems with it compared to my old leaky Q-jet. I really can't compare it to a carb that was in need of a rebuild though. All I can say is that when I need a carb for another car/truck I will be picking up another edelbrock.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 06-15-2004, 02:19 PM   #10
CHEVYE
my gas saver
CHEVYE's Avatar
edelbrock makes an awesome carb for reliability and gas mileage. i`ve noticed the holley has a little more response to them. i don`t know if this is characteristic of all carbs but i got on a steep incline onE time towing a buddy out and my carb loaded up badly. it was so rich it wouldn`t run unless it was floored. i thought gas was going to drip out of my tailpipe.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 06-15-2004, 03:57 PM   #11
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
What's an easy way to tune it? Mine isn't bad, but its a little rich (you can really smell it sometimes) but when I lean it out, it gets way too lean and the idle is all rough. Any suggestions?
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 06-15-2004, 05:39 PM   #12
68 Suburban
I would e mail edelbrock tech and let them know your set up. They will let you know what to use. They even sent me the needles and jets that I needed for free!!
Old 06-16-2004, 01:27 PM   #13
ko72
I am running a edelbrock performer 750 on my bbc and get about 6-8 mpg and cant tune the thing. I would not suggest the 750 for anything.
ko72 is offline   Reply With Quote
Old 06-16-2004, 10:12 PM   #14
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
One things you guys need to check out before you do any drastic tuning is that these Eldelbrock carbs dont need 7-9psi fuel pressure like Holleys...They only need 4-5psi at the most. Just call and ask the tech support when you call about the tuning. It will make a total difference in these carbs. They are great out of the box but better with a fuel pressure regulator.
thanks
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 06-18-2004, 04:41 AM   #15
jlmtrout
I bought mine rebuilt from Summit, and all I did was take it out of the box, bolt it on, hook it up and go. Never had a moments trouble out of it and haven't touched it to tune it. I'm running a 1406-600 cfm. Good luck and keep on truckin'...........Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
Old 06-18-2004, 01:08 PM   #16
Jeepster376
Jeepster376's Avatar
68 Suburban, do you remember what jets you ended up running?
BTW, I have a Carter AFB (not Edelbrock but same as 1406) and it runs mint now after I spent a little time getting it all dialed in.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 06-18-2004, 01:48 PM   #17
Beefcake
Never rebuilt a carb, edelbrock 1406 was my first. Piece of cake. Love the performance and mpg. I have no complaints.
72 GMC Camper Special 2500.
currently has 350/350/14 bolt. 383 and 400 tranny is in the works.
Beefcake is offline   Reply With Quote
Old 06-18-2004, 02:01 PM   #18
piecesparts
Parts and more parts
piecesparts's Avatar
I would consider the NEW Edelbrock Performer carb (With the adjustable secondaries). That would allow for more fine tuning of the transition into the WOT condition than the original line. I am running a Carter AFB and an Edelbrock AFB (Same body design and parts in both of them) and I like them for performance and LACK of trouble. The Holley and Demon have a vacuum secondary and that creates a smoother transition, but can be painful if it is out of adjustment. The 750 carb is great for an all out top end, you can even buy an 800 cfm. For general everyday street driving the 625 cfm carbs is the choice. The 750 and larger creates a bog in a heavy vehicle and then tends to waste gas. The principal is to keep the air flow (velocity) up so that the engine is responsive. You will give some top end performance away, but keep driveability and gas mileage.
Old 06-18-2004, 03:07 PM   #19
kickinasphalt
kickinasphalt's Avatar
Just installed an Edelbrock 1406 (600cfm,electric choke) on my 72 4x4 along with there new EPS intake. Once I got the motor timed it seems to run great. BTW, there is a rebate going on right now if you buy a new carb and intake.
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73
1972 C-10 Longbox,350/350
1998 Pontiac Grand Prix GTP
FOR SALE: 1971 K-10 Longbox,350/SM465/NP205
kickinasphalt is offline   Reply With Quote
