Old 02-22-2020, 07:05 PM   #1
reeltales
reeltales's Avatar
Hurst Comp plus mounting plate
The 71 C10 I bought had been converted from a 3 on the column to a floor shift. I just bought a Muncie M20 and found a Hurst Competition Plus shifter. The guy had the shifter linkage but did not have the mounting plate. Does anyone know what mounting plate part number I would need? or what installation kit they used, which might show me the mounting plate number.
reeltales is offline   Reply With Quote
Old 02-22-2020, 07:09 PM   #2
reeltales
reeltales's Avatar
Re: Hurst Comp plus mounting plate
A picture of the plate may also be enough to track down what I need
Old 02-22-2020, 10:17 PM   #3
franken
Might try google...
https://www.google.com/search?sxsrf=...99.ebRU6kuY8CM
Old 02-23-2020, 08:46 AM   #4
reeltales
reeltales's Avatar
I did the Google search prior to posting the question. I also did a search of this forum but could not find the answer. What I found was there appears to be two type of plates for the Chevy/Muncie. One is a single plate while the other has a front plate along with a spacer plate. I was trying to find which one the guys on here had used in their projects.
Old 02-23-2020, 10:47 AM   #5
reeltales
reeltales's Avatar
I was able to contact a tranny rebuilder and found the correct mounting plate.
