Lowering questions
I have a 70 C10 and am wanting to lower it. I am going to do a disc brake conversion and wanted to know how to lower. I want to do the 2/4 drop. So when I do my brakes do I install drop spindles and stock height springs or do I use stock spindle and lowering springs? The rear is coil so I know just springs back there.
Re: Lowering questions
Look at some others that have posted...for the rear springs, combination of drop blocks and lowered springs for a better ride. I cut my drop blocks on an angle (a wedge) to keep the pinion angle correct.
On the front if you are lowering 2", it will be 2 1/2" with the spindles. But this is what I would do. Since you are buying the spindles either way, I would get the drop spindles and put it together with your OEM springs. That way when you want to go lower, you haven't spent the money on springs. And most likely, you will want to go a little lower. Then you can buy the lowering spring you want to get the final ride height. Buy once and not twice! (or more...)
#4 | |
I would start with 5” in the back I think. Mine is lowered 4 1/2” front and 7” rear and the 2 1/2” difference is good IMO.
Although 4” springs gives you option of adding 1” blocks if you want it dropped just a little more and cheaper than second set of springs.
I have found that 3/5 is the perfect lowering job for the lowering newbie or the guy who just wants a comfortable drop. 2/4 is barely noticeable.
As far as I’m concerned all lowering on these trucks should start with a drop spindle, there is absolutely no change in ride quality with a drop spindle.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#7 | |
![]() ![]() Join Date: Sep 2008
Dropped spindles in the front with OEM springs, and 4" springs in the rear.
