#1 | ||
73-75 Gauge Tachometer
79 Chevy 2wd BIG10 350 TH400 |
Re: 73-75 Gauge Tachometer
Yes, the meltdown being referenced there is due to the ammeter vs. the voltmeter and has nothing to do with the tachometer.
The coil inside the ammeter has very low resistance and will act like a short circuit if it is connected to the wiring that is configured for a voltmeter. So yes, you can swap a voltmeter into the cluster to use it in your 79. If I remember correctly, the terminals on the back of the gauges are oriented differently for the ammeter vs. voltmeter so the voltmeter won't plug directly into the earlier cluster. You'll probably have to make up a small jumper lead to connect one of the voltmeter terminals to the cluster's printed circuit. Also be aware that the cluster connector pin-outs are different for 73-75 vs. 78+ so you'll also have to re-pin the connector to use the 73-75 cluster in your 79. And you will also have to add an oil pressure line since the 73-75 cluster will have a mechanical oil pressure gauge instead of electric. EDIT: If your 79 already has gauges (but no tach), a 1978 or newer tach cluster would be a direct plug-in swap. So it would probably be easier to see if you can sell or trade the 73-75 tach cluster for a 78 or newer one. Last edited by ray_mcavoy; 02-24-2020 at 05:51 PM. |
| Bookmarks |
