Old 01-24-2020, 07:05 PM   #1301
CHROMAHOLIC
CHROMAHOLIC's Avatar
Re: off it goes
Originally Posted by blazer2007 View Post
Just wondering if you have any plans on another build since this one is coming to a end ?
I have plans...the wife has other plans. lol, no this will be the only one I build to this level. I have lots of nice cars over the years but nothing to this degree. This is a one and done for me....
CHROMAHOLIC is offline   Reply With Quote
Old 02-16-2020, 01:29 PM   #1302
Warrens69GMC
Warrens69GMC's Avatar
Re: off it goes
*Ahem*
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 02-20-2020, 02:44 PM   #1303
LT7A
Re: off it goes
I'll never get tired of the details. So keep this thread going with how you use it and post previously unposted pics of the work process. I'll Look!
Old 02-25-2020, 08:01 PM   #1304
CHROMAHOLIC
Re: off it goes
front end is completed...got a few more pieces put on under the hood
Old 02-25-2020, 08:05 PM   #1305
CHROMAHOLIC
Re: off it goes
buttoning up some things on the interior now that we got all the gauges working. Has any issue with no fuel gauge but turned out to be a faulty sending unit, all fixed... Also took the NOS door handles and polished the inserts to a mirror finish, being as there is nothing else on the truck brushed. Polishing the shifter, tilt lever and signal as well
Old 02-25-2020, 09:38 PM   #1306
SCOTI
SCOTI's Avatar
Re: off it goes
Jeez. Us. Man.... the details on this.
Just outstanding.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-25-2020, 10:49 PM   #1307
kipps
Re: off it goes
As the engine rocks in its mounts, will it over-stress the intake tube? I'm not seeing any flex joint in the intake.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 02-25-2020, 11:45 PM   #1308
Loco83
Loco83's Avatar
Re: off it goes
Just outstanding.
Amen to that!
Loco83 is offline   Reply With Quote
Old 02-26-2020, 02:15 AM   #1309
ajgriffin
ajgriffin's Avatar
Re: off it goes
Crazy good.
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 02-26-2020, 09:10 AM   #1310
Hart_Rod
Hart_Rod's Avatar
Re: off it goes
Dayummm this truck is beautiful!!!!
Hart_Rod is offline   Reply With Quote
Old 02-26-2020, 10:45 AM   #1311
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: off it goes
Just outstanding.
uuhhm... yea I think this sums it up!!! exquisite!!
question: could/would you go into a little detail of how/what you did for the body "vent openings"- wiper arms openings above the firewall (post 1256) I would like to try to do something similar... thank you in advance
rodstored-72 is offline   Reply With Quote
Old 02-26-2020, 07:31 PM   #1312
CHROMAHOLIC
Re: off it goes
the two band clamps right at the intake are on a rubber tube...it just blends in well with the intake tube
Old 02-26-2020, 07:38 PM   #1313
CHROMAHOLIC
Re: off it goes
the vent opening up by the wiper arms I laser cut from a piece of 11 Ga. stainless and then we built wooden bucks the same shape as the holes and we then formed the stainless wire mesh to fit inside the holes. My intention at one time was to leave it shiny but I changed direction through the project and painted everything. I wanted it all to blend and kind of get lost with everything else so we painted it body color. As for the wipers...here's hoping I don't get caught in the rain, lol. I went with a cable driven wiper system from a street rod so that this way there would be no big ugly wiper motor on the firewall.
Old 02-26-2020, 07:39 PM   #1314
CHROMAHOLIC
Re: off it goes
thank you everyone for the nice comments...truly appreciate it
Old 02-27-2020, 12:16 AM   #1315
rodstored-72
chevy truck fan
Re: off it goes
thank you for your answer, it appears that the laser cut piece is attached at the factory holes? also would you share how the wire mesh is attached to the laser cut piece?
thank you again
Old 02-27-2020, 12:09 PM   #1316
CHROMAHOLIC
Re: off it goes
thank you again
Yes laser cut piece is an exact copy of the factory plastic one, so yes mounting holes all lined up. As for the mesh, we used a panel bond adhesive to keep them in place. We used the panel bond because at that time I was leaving the finish mirrored so we couldn’t tack weld it, but now that we painted it we could of done a small tack to keep them in place.
Old 02-28-2020, 06:34 AM   #1317
Hammered 77
Hammered 77's Avatar
Re: off it goes
I like the filler pieces you made for the bumpers. Did you attach them to the body or to the fenders?
Rick
Hammered 77 is offline   Reply With Quote
Old 02-28-2020, 06:57 PM   #1318
CHROMAHOLIC
Re: off it goes
Rick
Thanks, they are attached to the body of the truck,
Old 03-17-2020, 07:01 PM   #1319
CHROMAHOLIC
Re: off it goes
a little interior action going on in the shop
Old 03-17-2020, 07:07 PM   #1320
ajgriffin
ajgriffin's Avatar
Re: off it goes
NICE!
Old 03-19-2020, 06:58 PM   #1321
CHROMAHOLIC
Re: off it goes
thanks man
Old 03-20-2020, 06:37 PM   #1322
Hart_Rod
Hart_Rod's Avatar
Re: off it goes
This has to be the nicest Squarebody ever built (EDIT: hell, it might be the nicest truck ever built...). It is on my bucket list to see it once it's done.
Old 03-22-2020, 05:32 PM   #1323
kipps
Re: off it goes
Hart-Rod's comment is definitely not hyperbole!!
Old 03-25-2020, 06:23 PM   #1324
CHROMAHOLIC
Re: off it goes
thanks guys...I appreciate the compliments
Old 03-25-2020, 06:26 PM   #1325
CHROMAHOLIC
Re: off it goes
started to put outside mouldings on....
