Old 02-27-2020, 10:26 PM   #1
Tntruckowner
Needing a parking brake cable
I have a 68 C10 with a rear end charge someone put a 12 bolt rear end in the truck before I got it and don't know what end cable to order for the parking brake the end that goes into the wheel can anyone help
Tntruckowner is offline   Reply With Quote
Old 02-27-2020, 11:16 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Needing a parking brake cable
From my experience with a 1971 C10, you at least need to ID LWB or SWB, coils Vs leaf springs, and connector type at the wheel plate.
In my case the reputable dealer still sent the wrong ones. That's what I get for a SWB, 2WD C10 W leaf springs "they'd never seen before". I had to send them the right ones.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-28-2020, 08:22 AM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Needing a parking brake cable
LMC has the cables and such.
#5 is the cable going into the back wheel.
https://www.lmctruck.com/1967-72-che...g-brake-cables
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-28-2020, 09:31 AM   #4
67C10Step
67C10Step's Avatar
Pictures of the backing plate for the brakes would help. As was stated before, coil or leaf spring and long or short wheelbase. I just replaced those exact cables on my 67 and got AC Delco cables from RockAuto. Not very expensive and fit like the originals.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
