Old 02-28-2020, 08:46 PM   #8
PGSigns
PGSigns's Avatar
Re: Wheels for 64 fleetside ?
The front will be close. A lot depends on the tire. The rear about all you can use is 4" of back spacing depending on the tire section width with out wider wheel wells. I always recommend the use of a wheel back pace tool on the truck the wheels are going on and use the tire you want to run. Lots of times you can buy used tires cheap in the size you want to run for testing fit. A tool like this can save you a lot of money of wheels. https://www.amazon.com/Ingenuity-Fab...87016726&psc=1
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
