Are BBC engines free spinning or interference engines
Are the older BBC engines (70 C10 402) free spinning or interference engines?
I’m fearing I broke timing chain. Before tearing into engine I was curious as to what I’m getting into. Also does anyone know of a good honest reputable engine shop in the Dallas-Fort Worth Texas area.....just in case I need it? |
Moderator
![]() Join Date: Jun 2017
Re: Are BBC engines free spinning or interference engines
Sadly, yes they are interference engines....all BBC variants will bend valves and push rods if they break a timing chain.....
Life sometimes throws you a curve, but remember, you are not alone and we are all here to help you out if needed. After a good nights sleep, a simple one hour diagnosis will tell you where you stand First off, dont use the starter to turn the engine during these tests.... Pull the dist cap and hand turn the crank and watch the rotor button....if the rotor doesn't move it is most likely a broken timing chain. Pull the rocker covers and slowly turn the engine by hand...if the valves do not move, this will confirm the broken chain suspicion. Button it back up and consider next steps...please post your results after you are done with the above. Good luck ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() Last edited by AussieinNC; 02-28-2020 at 08:37 PM. |
Who Changed This?
![]() Join Date: Jan 2013
SBC engines are also interference engines, BTW. Those little crescent moons in the pistons are only there to prevent contact between valves and pistons at high enough speeds. If the timing chain goes, it's going to be a mess of bent valves.
#4 | |
https://www.waynecalvertengines.com/ Last edited by lil hoodlum; 02-29-2020 at 01:37 AM. Reason: spelling corrections |
