Moderator
![]() Join Date: Oct 2008
Re: 1973-1991 Dual fuel tank systems theory of operation
Probably one of three things not in order of probability. Test first then replace or repair.
Power is hot with the ignition switched ON. Ground is Ground all the time. The B terminal of the valve plug gives you access to the other end of the common gauge wire. Don't overlook the plastic printed circuit. If you have higher than one ohm resistance from the sender clips to the B terminal at the valve pull the cluster bucket, being careful not to break off the tabs, and unplug the cluster connector. Then you can test resistance from the fuel gauge wire on the cluster connector to valve terminal B and test the resistance of the printed circuit sender trace with a meter as well. Removing the nuts from the bias resistor on the back of the gauge and re-installing with star washers can fix dodgy connections to the resistor. Don't be a ham handed gorilla when you tighten them back down... you can and will crack the ceramic substrate of the resistor. Snug with a nut driver is good enough. If it looks like the resistor is cocking to one side loosen it up and get it level with the back of the gauge can.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 03-02-2020 at 12:00 PM. |
| Bookmarks |
