Old 03-05-2020, 08:15 PM   #1
spspspspoon
Power Steering!!??
SBC power steering pump
with stock steel mount?
Picked up a new power steering pump( 20-7920F) as well as bracket
pump does not have lower rear mounting stud!??
And all the mounts I've seen (exc my bent to stock steal one) seem to require lower rear mounting stud??
I need either a mount that works With Out Rear Lower Mount Stud
Or the same type I have maybe smaller or? and has a Rear Mount Stud
mounted lower driver position
LWP
spspspspoon is offline   Reply With Quote
Old 03-05-2020, 08:28 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Power Steering!!??
What was the middle thing again?
Old 03-05-2020, 08:53 PM   #3
PGSigns
PGSigns's Avatar
Power Steering!!??
You can put the new guts in your old can. Careful on the colorful language, it is a family oriented site.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-06-2020, 01:37 AM   #4
Killer Bee
Killer Bee's Avatar
Power Steering!!??
if yer that excited over the wrong parts, may want to consider a new hobby..
as for the correct bracket/pump configuration. your application information may lead a board member to a solution for you..
good luck!
Old 03-06-2020, 03:04 AM   #5
spspspspoon
Power Steering!!??
Not at all Sorry
just slowly replacing stuff on my engine finding out that the parts were just beating up and more used than previously thought
I've been wrenching for 30+ yrs
we all have those F it moments
I ended up taking apart my old pump and noticing that the pump itself has the threads in it to put that mounting bolt so I'm going to have to just drill into the case and put the mounting stud there
But again the bracket that I picked up fits too snugly to the pump sides and not enough room to even adjust it if mounted correctly
seems that my pump is a little taller than the ones I've seen in all of the pictures
metric?
my pump to box hose seems to be both flanged And O ring?
Old 03-06-2020, 08:15 AM   #6
kens65fb
Power Steering!!??
Originally Posted by spspspspoon View Post
Not at all Sorry
metric?
Apparently you are working with mismatched parts.
Save yourself AND us, a lot of grief, just get the correct pump, and correct bracket, and move on.
kens65fb is offline   Reply With Quote
Old 03-06-2020, 10:56 AM   #7
rpmerf
rpmerf's Avatar
Power Steering!!??
Some thoughts.
Unless you've owned the truck since new, you don't know what has been changed over the years. Really inspect old parts before buying new parts. Don't be surprised when things don't fit.
I usually go on Rock Auto and look closely at pictures, and options before buying anything. Look for parts for later generations also, they might had been swapped in years ago.
You mentioned metric. I think power steering stuff switched to metric sizes about 78ish. Might look for the hoses you have to figure out the pump you have.
If you need brackets, I would look at Summit
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 03-06-2020, 12:48 PM   #8
Corts60
Just here to tinker
Corts60's Avatar
Power Steering!!??
Not at all Sorry
metric?
Usually the fitting is inverted flare I believe. Pics would help.
I also second keeping the language clean. A lot of great people on this site who are here to help.
Old 03-06-2020, 05:36 PM   #9
REDROCKER652002
Power Steering!!??
Having to deal with my son's 69 and it's mismatched parts, I feel your pain. Keep at it, and relax. Have a beer, take a deep breath and post away. Somebody here is gonna be able to help you out. My son's front brake setup was from a 72, his heater in the cab was from who knows where. LOL. That is part of the fun of dealing with an old truck that you have no idea where it came from. Take it slow, enjoy the ride and relax man. Have a beer, don't cost nuthing. LOL
REDROCKER652002 is offline   Reply With Quote
Old 03-06-2020, 06:43 PM   #10
MySons68C20
MySons68C20's Avatar
Power Steering!!??
Can the mod change the title of the thread?
MySons68C20 is offline   Reply With Quote
Old 03-06-2020, 07:42 PM   #11
ImpalaJim
ImpalaJim's Avatar
Power Steering!!??
I myself curse nonstop but its NOT needed here!!!!
ImpalaJim is offline   Reply With Quote
Old 03-06-2020, 08:48 PM   #12
REDROCKER652002
Power Steering!!??
He didn't curse. He just vented. LOL. I think the symbol thing has been used for ever, so let's just relax folks. We are all adults here. Again, have a beer, don't cost nuthin. LOL
Old 03-07-2020, 12:58 AM   #13
slepysal
slepysal's Avatar
Power Steering!!??
I thought he was taking about a Mount Franklin power steering pump......
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 03-07-2020, 01:39 AM   #14
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Power Steering!!??
Stinky poo poo boogger eating tissue wipe!
I am so mad!
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-07-2020, 08:05 AM   #15
The Rocknrod
Moderator
Power Steering!!??
Same here (as you can imagine). One of things I like about this site.
Old 03-07-2020, 09:20 AM   #16
70cst
70cst's Avatar
Re: Power Steering!!??
This tittle is not acceptable ... these forums are geared towards a family oriented site.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-07-2020, 09:22 AM   #17
70cst
70cst's Avatar
LWP
This tittle is not acceptable ... these forums are geared towards a family oriented site. Your title was changed along with the heading in each response. ... Please adhere to the rules and keep these post family friendly. Thanks
Old 03-07-2020, 11:10 AM   #18
LostMy65
LostMy65's Avatar
That's how grown-ups talk.
Old 03-07-2020, 11:34 AM   #19
AcampoDave
AcampoDave's Avatar
If you start letting good manners slide, foul language eventually turns into personal insults....I've seen it on other forums while researching various projects. I appreciate the fact that the rules are enforced around here.
AcampoDave is offline   Reply With Quote
