Old 03-06-2020, 09:06 PM   #1
nsb29
nsb29's Avatar
P2176
I modified my own harness had it all hooked up to the engine everything worked. I took it off and put it in a box, now the truck is together and I’m installing the wiring, I have zero throttle response and when I turn the key on I immediately get a check engine light, I get the p2176 code and says the Tac System idle position not learned I also get a code P2127 which states TPS pedal position sensor switch E circuit low input Any help would be greatly appreciated
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 03-06-2020, 10:27 PM   #2
plumber452
Re: P2176
I am at a similar junction in my swap. I have test ran my engine outside of the truck after reworking the harness myself. I tied all the grounds together and hooked them to the battery negative and everything worked great.
I'd say you have a grounding issue. If everything was O.K. prior to installing in the truck then this is the only thing that has changed. Good luck and keep us posted.
plumber452 is offline   Reply With Quote
Old 03-07-2020, 11:30 AM   #3
nsb29
nsb29's Avatar
Re: P2176
Went over the grounds several times, my fuel pump cycles when ignition is turned on. No fuel line yet but will check for spark. Starter relay uses the same grounds it works fine
Old 03-07-2020, 09:43 PM   #4
ls1nova71
ls1nova71's Avatar
Re: P2176
Check for backed out pins in the throttle pedal harness and at the ECM. Pretty much can only be the wires between the pedal and the ECM. Could also check the plug at the throttle body itself, just to be sure.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
