#301 | |
Re: HP Tuners Tutorials
I got a new daily driver a newer GMC Sierra that has the gen 5. Since I have HP tuners I decided I cant leave well enough alone so I am just sticking my toe into this. It is complex but something to look into and I am sure you understand that. I do like the gen 3 motors they are great and have tons of potential. they will be around a long time and we will all continue to enjoy them. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#302 |
![]() Join Date: Aug 2014
Re: HP Tuners Tutorials - Timing
Timing - Knock Retard Amount
Here we take a look at the total Knock Retard Amount table found under: Engine \ Spark \ Retard tab \ Knock Retard section \ Amount tablethe PCM is willing to yank out up to 35 degrees of timing in my case, however this is as good of a time as any to mention the additional Multiplier tables, which take a complex system and make it even more complicated, ha ha Engine \ Spark \ Retard tab \ Knock Retard section \ ECT Mult tableDirectly to the right of this table is the ECT Mult table think of this table as that annoying friend that always chimes in when you try to tell a good story and corrects you all the time. So for example you say man I went to the Kings basketball game last night and they killed the Clippers, and your buddy goes, actually the final score was only 88-86. You get what I'm saying!? So the ECT Mult table watches the engine coolant temp (there it is again the importance of keeping your engine properly cooled/heated) and for example when the temp is only 68 degrees and the PCM goes I'm gonna pull out 21 degrees of timing cause according to the Amount table that's what I gotta do at 800 RPM, the ECT Mult (your annoying buddy, goes) um not so fast the coolant temp is only 68 degrees at the moment so only pull out 75% of that 21 degrees. Got it? Last edited by Gregski; 02-27-2020 at 10:29 AM. |
#303 |
Timing - Burst Knock Retard
Burst Knock Retard (pronounced: Predictive or Preventive Knock Retard) is a means of pulling timing out before a knock even happens based on an abrupt throttle change resulting in a sudden drop in cylinder airmass. the Burst Knock settings are found under Engine \ Spark \ Retard tab \ Burst Knock Retard sectionHow big of a cylinder airmass change needs to happen before the PCM can take preventive action is defined in the Enable Delta Cyl Air table (delta meaning change or difference) if you were to upgrade to a bigger cam, you most likely would increase the numbers in this table to make it more tolerant and less reactive ie less sensitive. So for example once the PCM sees a 0.020 grams change at say 2,000 RPM it will consult the vs. RPM table to find out how much timing to pull out, and from what we can see at 2,000 RPM it will pull out 6 degrees of timing. So that's how that works. For beginners and stock(ish) engines we leave these tables alone. If you pinky promise to only put high octane 91+ in your tank and want to add a bit of gitty up into your truck engine you can experiment with increasing the numbers in the first table Enable Delta Cyl Air in the lower RPM range say 1200 RPM and under. Last edited by Gregski; 02-28-2020 at 09:51 AM. |
#304 |
Timing - Knock Learn Factor
Think of the Knock Learn Factor like a fuel gauge that goes from 1.0 to 0 (yes I did say it goes from 1 to 0 which is backwards, but hey GM did not reverse\fix that until Gen IVs) So when the Learn Factor is at 1.0 we are using the High Octane table values ie aggressive timing. When the Learn Factor is low ie 0 we are using the Low Octane table, mild timing, that's one way to remember it. Now the PCM will skew the timing by some factor when the Learn factor falls between 1 and 0 but that's for it to figure out. |
#305 |
Timing
Here's a look at not a very happy Knock Retard graph. Alright so armed with all this knowledge how do we actually get rid of the knock if we are experiencing some? Last edited by Gregski; 02-28-2020 at 10:52 AM. |
#306 |
Timing
What I would do is first I would select all the cells in the histogram. Then I would copy all of them, like so. Last edited by Gregski; 03-07-2020 at 01:26 PM. |
#307 |
Timing
Then go to the VCM Editor and pull up the High Octane table. Next right click anywhere in it and select Paste Special - Subtract. Last edited by Gregski; 02-28-2020 at 10:53 AM. |
#308 |
Timing
This will remove the right amount of timing advance in the precise cells where the knocking is occurring. Or you can change the values manually. Either way, eye ball the results and make sure there are no huge jumps, 2 to 4 degree differences between cells are acceptable, anything more than that and I would interpolate, meaning adjust the neighboring cells a little so the changes are more gradual For example, if we changed what ever number to 16 below 9 - 11 - 16 - 21 - 23 I would make the end result look something like this 9 - 12 - 16 - 20 - 23 to make the transitions be more gradual Keep in mind we are pasting values that are averages so there is some gentleness already built in to what we are doing, however it still may take some time to get this dialed in. TOP TIP: Before making any timing adjustments, top off your fuel tank with some fresh high octane 91+ as it does make a difference, and retest ie repeat the test drive and collect another set of data, the knocking may have subsided on it's own. |
#309 |
and that's that for Timing, we will cover Idle Tuning next
#310 |
Re: HP Tuners Tutorials - Idle Tuning
Idle Tuning
Idle tuning can be the most challenging, let's see if it has to be that way. We will begin with a few assumptions: 1. Your engine starts, so this is not about getting it to fire up after a cam swap.As we dive in deeper you will see that this reduces our complexity from 4 conditions to only two, where we idle either: 1. In Park Last edited by Gregski; 03-07-2020 at 03:56 PM. |
#311 |
Idle Tuning
So to tune the idle phase of your engines operation we will focus on the Holy Trinity: 1. RPMAs always we start off with a clean canvas in the VCM Scaner, and begin by adding the channels we will need. |
#312 |
Idle Tuning
Hopefully by this time I don't need to convince you why we always start with the Engine Coolant Temp channel regardless of what we are doing. This channel is just something we have accepted we will always need to guide us with the meat and potatoes of what ever our mission is. Last edited by Gregski; 03-08-2020 at 11:27 AM. |
#313 |
Idle Tuning - RPM
We start tuning idle by expecting or dictating at what Engine RPM (Revolutions Per Minute) our engine will sit there in our garage or driveway and purr like a kitten. So what should that be? A wise old timer once told me, "let her idle at the lowest RPM she will stay running at." that advice has stayed with me for over 20 years, cause otherwise you are just sending dollar bills out your tailpipe sort of speak. Now there's more to it then that, she needs to stay running at all conditions so in Drive aka in gear as well as in Park/Neutral. So just cause we can get our engines to idle at 450 RPM in Park doesn't mean they will like that when we are stopped at a red light in gear. So let's add our first channel for idle tuning, Engine RPM and see where she idles at. A nice analog Tach is highly recommended for idle tuning, anyone who calls themselves a Hot Rodder ought to have a tachometer installed in their rig. Please Note: we also assume your build is complete, in other words the Air Filter housing is on, the air intake is on, you have complete exhaust system bolted up, etc. Last edited by Gregski; 03-08-2020 at 11:27 AM. |
#314 |
Idle Tuning
Now things have gotten a bit more advanced, since that old man's advice. GM engineers have already predetermined at what Engine RPM our LS engines ought to idle at, so lets take a peak at those settings in the VCM Editor. Engine \ Idle \ RPM tab \ Base Setpoint section \ Base table |
#315 |
Idle Tuning - Base table
In the Base table we see the four conditions our engine can be operating at while idling. We agreed to only focus on the two without the AC to make things a bit easier. 1. In Gear AC offOnce warmed up we should be in the green zone so our RPM should be 550 in Park and 525 in Gear. Note: My numbers are based on a 2001 GMC Sierra 4.8L 4L60e 2WD, your numbers may vary. Last edited by Gregski; 03-07-2020 at 03:07 PM. |
#316 |
Idle Tuning - Idle Desired RPM
Now we could commit those numbers to memory, or write them on a post it note, or take a pic of that table with our iPhones, but we don't need to. You see HP Tuners makes our lives so much easier, by providing us with a channel called Idle Desired RPM. The nice thing about this parameter / channel is that the value will change in real time based on whether we are in Park or in Gear so it will always show us what the PCM expects the idle RPM to be dynamically, very cool. So let's add it to our Channels. Last edited by Gregski; 03-07-2020 at 04:01 PM. |
#317 |
Idle Tuning - Engine RPM vs Idle Desired RPM
So now our Channels look like this: Engine Coolant Tempand that is the first part of the Holy Trinity, that's all we need to discuss the engine RPM aspect of the idle tuning process Last edited by Gregski; 03-07-2020 at 03:06 PM. |
#318 |
Idle Tuning
So let's go out there and get some data in this NorCal early March treacherous weather (pronounced: sprinkling) Last edited by Gregski; 03-07-2020 at 02:19 PM. |
#319 |
Idle Tuning
Having logged over 20 minutes of data lets take a look at the numbers. We have learned that my in Park Idle Desired RPM should be 550, so why is it 700 in the screen shot below? |
#320 |
Idle Tuning
lets troubleshoot / explain what is going on here together we start by looking at our ever important Engine Coolant Temp channel and it clearly only reads 90° F this has got to be a red flag, seems kinda low for a fully warmed up engine |
#321 |
Idle Tuning
lets go back and consult our idle Base table to see what should be happening at 90° F and sure enough, the Desired Idle RPM is 700 at 90° F in Park, the engine hasn't fully warmed up yet, I just jumped the gun, this happens to more people than you know now I wasn't trying to trick you, or be a smart alleck, you must fully warm up your engine for it to settle in the specs it needs to settle in at Last edited by Gregski; 03-07-2020 at 03:43 PM. |
#322 |
It may have taken me 20 minutes for my truck to fully warm up to about 194° F where she likes to settle in, and that's ok, it would have happened faster if I was to drive her around the block, but I wanted just to log some pure data in Park So here's what the numbers look like in Park when the engine is warmed up: Engine RPM = 552pretty darn perfect Last edited by Gregski; 03-07-2020 at 03:06 PM. |
#323 |
now watch what happens when I shift her into Gear Engine RPM = 525the Idle Desired RPM changed from 550 to 525 and the actual Engine RPM followed, as it should per the Base table, see how that works Last edited by Gregski; 03-07-2020 at 03:06 PM. |
#324 |
Idle Tuning - Chart vs Time
In order to further our RPM discussion it is time to get acquainted with a new feature of HP Tuners called Chart vs Time. |
#325 |
Idle Tuning - Chart vs Time Layout
We add a Chart to our Layout in a similar fashion we have been adding the Histograms from the main Menu above Layout \ Add to Layout \ Chart vs time Last edited by Gregski; 03-07-2020 at 04:04 PM. |
