Old 06-18-2004, 04:49 PM   #1
stea
prepping new motor for paint
finally received my new motor from GMPP, I need to prep it for paint, what should i use to pre clean the motor before sanding? Looking for an aerosol that wont leave a residue.
stea is offline   Reply With Quote
Old 06-18-2004, 05:52 PM   #2
MrGoodpliers
MrGoodpliers's Avatar
I would suggest a wax/grease remover (available at your auto paint supply store) before and after sanding. I'm not sure if it comes in aerosol, though.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 06-18-2004, 05:57 PM   #3
jorgensensc
jorgensensc's Avatar
From what I've heard before on this board:
Go to the dollar store and buy the cheapest oven cleaner you can find. A few cans will eat right through everything, including grease and paint.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 06-18-2004, 06:48 PM   #4
Big J
Its lookin' like a Blazer!
Big J's Avatar
Yep, Dollar General oven cleaner. Works great. I tried all kinds of degreasers on my stuff, tranny-trans, the oven cleaner was the only thing to take it off.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 06-18-2004, 06:55 PM   #5
stea
sounds good, ill give the oven cleaner a try.
Old 06-18-2004, 08:06 PM   #6
cdowns
cdowns's Avatar
i don't see any need for the use of caustic oven cleaner on a new engine
Old 06-19-2004, 01:30 AM   #7
1972C10
1972C10's Avatar
lacquuer thinner and scotch brite if you think it needs it
Alot of times i just spray over exsisting paint as long as its stuck and feathered out if its chipping.
1972C10 is offline   Reply With Quote
Old 06-19-2004, 07:33 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I load my paint gun with laquer thinner and turn the pressure up real high and spray the hell out of the engine. The excess drips off onto a pan under the engine stand. Laquer thinner is an excellent solvent and will remove any oils on there now.
Then, I use the POR-15 engine paint kit. The end result is bombproof.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 06-19-2004, 06:26 PM   #9
Truck Hippy
Truck Hippy's Avatar
Now thats pretty!! The motor not you TX!! HAHA Wes.
Truck Hippy is offline   Reply With Quote
