Old 04-27-2017, 09:10 AM   #1
Mattchu60
LMC Tach for 1987 Model?
I have been looking at the LMC Tach for some time, would love to have that factory looking tach in my dash. I have read some of the write ups on here about installing one into a cluster and how to relocate the fuel gauge.
One big mystery I have stumbled into is if this will even work on my truck - I have a 1987 model with EFI. I have read somewhere that this model year cannot have a tach, because 87 EFI trucks have speed sensor (VSS) feedback needed for the factory EFI computer.
I wouldnt think the VSS would be affected by the tach, but i have never tore into a cluster before so maybe its on a spot where it wont work?
If anyone has done this on an 87' model, I would appreciate input. Thanks!
Mattchu60 is offline   Reply With Quote
Old 04-27-2017, 09:29 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: LMC Tach for 1987 Model?
My '87 TBI truck came from the factory with the tach cluster.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-27-2017, 09:31 AM   #3
SCOTI
SCOTI's Avatar
Not sure on your specific model but I converted my 89 CC dually w/TBI to a tach dash & relocated the fuel gauge over to the blank spot w/the smaller gauges.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-27-2017, 09:45 AM   #4
Mattchu60
Sounds like its a non-issue then - SCOTI - did you cut a hole in your stock cluster and run wires over to the new fuel gauge spot like I have seen some do - reusing the stock printed board? Or did you handle it differently?
Old 04-27-2017, 11:20 AM   #5
SCOTI
SCOTI's Avatar
Yes, yes, & re-used the original printed circuit board.
I used the LMC small fuel gauge & a 7k tach w/both using the later year models font so everything matched the remaining OE gauges.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-27-2017, 11:55 AM   #6
Mattchu60
I like the look of that 7k tach - where did you get it at? - the LMC ones are all 5k tachs.
How difficult would you say this install is? I know its always a pain to take the dash apart for me - seems like it takes a good amount of time to get it all out and then back together for me.
Old 04-27-2017, 12:06 PM   #7
Dads79GMC
Dads79GMC's Avatar
Mattchu60, I'll be watching this. Please post the success you have. I have a 91 cluster for my LS conversion and would like a tach and relocate the fuel gauge as well. Good Luck, Mike.
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 04-27-2017, 12:33 PM   #8
SCOTI
SCOTI's Avatar
http://www.gmsports.com/tags/tachometer
Be advised though, they sent the tach & the 4 gauge cluster assembly. But, the font style for the 2 upper gauges were 81-87 while the lower 2 were 73-80. I was kind of pissed about that. So I ordered the correct font fuel gauge & did it that way. That 4-cluster set-up is still sitting in the box on a shelf.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-27-2017, 02:20 PM   #9
Mattchu60
Ok - I have seen these before - I don't really like that you have to order the new tach along with the 4 gauges as one unit, but i suppose it is convenient for some to do it that way vs buying a stand alone fuel gauge.
The 4 gauge pod seems to have the correct lettering in the picture for the bottom ones - but something does look "off" about the lettering, almost like its too small or something. maybe it would look fine once installed.
Old 04-27-2017, 02:56 PM   #10
Keith Seymore
Here's what the factory setup looks like (in terms of font) -
K
1979-1986
1986 - 2019
Old 03-10-2020, 01:30 PM   #11
Hart_Rod
Hart_Rod's Avatar
K
Does anyone sell a kit that allows this upgrade to a non tach cluster?
Hart_Rod is offline   Reply With Quote
Old 03-10-2020, 02:13 PM   #12
SCOTI
SCOTI's Avatar
Brothers or LMC are the only ones I've seen. I know LMC has them listed as a back-ordered item.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-10-2020, 05:07 PM   #13
Hart_Rod
Hart_Rod's Avatar
Found it, https://www.brotherstrucks.com/1981-...tinfo/TACH797/
Pretty pricey....
Old 03-10-2020, 06:23 PM   #14
SCOTI
SCOTI's Avatar
Agreed.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-12-2020, 12:55 PM   #15
Factory Guy
Factory Guy's Avatar
Usa1 parts has the same set up as well.
http://www.usa1industries.com/produc...cat=668&page=1
I am building my own as well.
Early mock up stages..
https://ibb.co/c8TD9Rq
Factory Guy is offline   Reply With Quote
Old 03-13-2020, 11:31 AM   #16
Desert1957
Desert1957's Avatar
Sorry I waited on purchasing a 7K tach, Looks likes the new ones are gone forever.
Desert
Desert1957 is offline   Reply With Quote
